  slave cylinder identification
slave cylinder identification by cartercarbaficionado
Started on: 10-02-2024 12:29 AM
Replies: 3 (74 views)
Last post by: cartercarbaficionado on 10-03-2024 10:43 PM
Report this Post10-02-2024 12:29 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
having to swap a getrag 5 speed into the formula due to the 85 v6 4 speed transmission blowing up the 1st and 2nd gear syncro in traffic. or bending gear teeth
anyways. is this a getrag or Isuzu slave? don't mind what way the bolt is going or pushrod length since both of those were cobbled together by the previous owner and are just kinda...there.
[This message has been edited by cartercarbaficionado (edited 10-02-2024).]
Total ratings: 154
Report this Post10-02-2024 10:10 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a Getrag slave cylinder.
Yellow-88
Report this Post10-03-2024 08:32 PM Click Here to See the Profile for Yellow-88Send a Private Message to Yellow-88Edit/Delete MessageReply w/QuoteDirect Link to This Post
So .... please explain how you to bend gears?
Is that a SS exhaust flange on that Y pipe?
Report this Post10-03-2024 10:43 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
someone apparently did it with a 85 4 speed. I haven't taken it apart yet so I'm not sure.
idk? it's just the fiero stores y pipe which fits like garbage and doesn't seal and unlike the stock y pipe blocks the trans from being installed with the subframe tilted
