  VSS gear
VSS gear by itzikbns
Started on: 10-02-2024 10:27 AM
Replies: 5 (117 views)
Last post by: fierofool on 10-03-2024 10:31 AM
itzikbns
Report this Post10-02-2024 10:27 AM Click Here to See the Profile for itzikbnsSend a Private Message to itzikbnsEdit/Delete MessageReply w/QuoteDirect Link to This Post
HELP!
I have an 86 SE 2.8 manual 4 speed, I probably dropped THE VSS plastic gear in to the oil pan, desperately looking to buy one, nowhere to be found... I posted on line and all I meat are crooks... any ideas? any other GM cars that share same part?
Total ratings: 200
Report this Post10-02-2024 10:39 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by itzikbns:
HELP!
Hi Itzikbns, this is like the hardest thing to find for Fieros. If you can't find one on eBay, then I recommend a few places:
Mikes Fiero Parts: Boysatt1@gmail.com
Larry Hubbert: LHubbert2@brighthouse.com
EDIT: I'd also add that it's probably better to have literally any gear in there, rather than no gear. I'm making an assumption, but you can probably adjust the signal coming from the VSS with a resistor or something... or maybe even on the gauge cluster itself.
[This message has been edited by 82-T/A [At Work] (edited 10-02-2024).]
itzikbns
Report this Post10-02-2024 01:35 PM Click Here to See the Profile for itzikbnsSend a Private Message to itzikbnsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for replaying, I will contact both
I have a programable speedometer, you think I can do with 29 tooths gear?
Itzik
Total ratings: 200
Report this Post10-02-2024 01:42 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know what your set-up is like. But I 100% think you can. There's multiple different gears that were available, and they would get switched out based on what the final drive in the transmission was... and even matched to the recommended tire configuration you had.
So honestly... in my opinion, if you can program your speedometer and even recalibrate it... it doesn't really matter what gear you're using, just so long as you can in fact get a signal from the VSS. So, you should be good if you can find a gear, any gear!
Report this Post10-03-2024 03:17 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
First step; if the gear fell into the transmission you must fish it out of there. With its steel shaft, it will cause transmission failure. If it fell elsewhere outside it should be somewhere on the floor. You might have to drain the oil, invest in a cheap fiber optic camera and buy a pickup tool.. GM tended to use the same parts in many applications. The gear to other GM VSS senders might fit. The Fiero VSS gear is hard to find. Mike Valentine most likely has one if not a trip to the junkyard might be in order.
Report this Post10-03-2024 10:31 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the gear you find isn't the correct one for your transmission/tire combination, you can use a GPS to compare speedometer to GPS speed and make a mental note of the difference at a given speed, whatever your common speed limit might be.
