  Rpm and Tack issues
Rpm and Tack issues by Wayne Renninger
Started on: 10-04-2024 12:56 PM
Replies: 3 (67 views)
Last post by: Dennis LaGrua on 10-04-2024 09:01 PM
Wayne Renninger
Report this Post10-04-2024 12:56 PM Click Here to See the Profile for Wayne RenningerSend a Private Message to Wayne RenningerEdit/Delete MessageReply w/QuoteDirect Link to This Post
After setting 15 years ,replaced everthing fuel system, car starts right up but when you hev the engine Antu suggestions, the tack pegs over high, replaced ecm and when the engine tries ti return to idle it revs back up on its own? Any suggestions? Thanks in advance.
Total ratings: 329
Report this Post10-04-2024 02:22 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try replacing the tach filter. Thats the little silvered colored cap with a wire attached that sits near the distributor. That will fix the tach problem. As for the idle racing that could be a big vacuum leak or a defective TPS sensor.
[This message has been edited by Dennis LaGrua (edited 10-04-2024).]
cartercarbaficionado
Report this Post10-04-2024 07:35 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
the revving back up is the iac over compensating due to a vaccum leak. block everything off and start from there
Total ratings: 329
Report this Post10-04-2024 09:01 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If possible, try to rent, borrow or build a smoke machine. That will easily tell you where any leaks are coming from.
