  Lowering
Lowering by LS4FieroGuy
Started on: 10-05-2024 12:16 PM
Replies: 19 (429 views)
Last post by: cliffw on 10-14-2024 07:26 PM
LS4FieroGuy
Report this Post10-05-2024 12:16 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey everybody I was just wondering what the cheapest way to lower the car 1 inch would be?
Joshua Seeger
Report this Post10-05-2024 12:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Two bags of concrete in the passenger seat.
IMSA GT
Total ratings: 250
Report this Post10-05-2024 12:39 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you cut the front springs, that will be free. The expense is lowering the rear.
Report this Post10-05-2024 02:07 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rears can be cut as well.
IMSA GT
Total ratings: 250
Report this Post10-05-2024 02:34 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats interesting. I never paid attention to them because I simply went with coilovers as soon as I purchased the car. I assume you can only cut the top of the spring since the lower part is conical?
LS4FieroGuy
Report this Post10-05-2024 04:08 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So the consequences is cut all four springs? Wouldn't that make my suspension loose?
Joshua Seeger
Report this Post10-05-2024 05:09 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct
I could see coilovers only if looking for more wheel clearance on the wheel/strut area
richard in nc
Report this Post10-06-2024 05:59 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
it is important how much you cut.i cut a coil off a 1984 camaro and it dropped too much.
Report this Post10-06-2024 06:23 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, the weight of the car is held by the springs.
Cutting them half of a coil won't affect ride harshness significantly or make your suspension feel loose.
It would be a good idea to modify the front suspension bump stops to prevent bottoming out the front suspension.
Do not use heat to cut the springs, use a saw.
Report this Post10-06-2024 07:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...which on the '84-'87 is a relatively major job (cutting, shortening, and rewelding the metal cones) compared to just needing to trim the rubber bump stops on an '88.
[This message has been edited by Patrick (edited 10-06-2024).]
LS4FieroGuy
Report this Post10-07-2024 09:47 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So would i cut all four springs 1 inch shorter? And would I just cut the bump stops an inch? And would I cut the springson the top or bottom? Thanks.
Joshua Seeger
Total ratings: 200
Report this Post10-07-2024 10:07 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Eiback Fiero Lowering Springs
https://www.ebay.com/itm/164124182471
Report this Post10-07-2024 11:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
LS4FieroGuy, why don't you tell us what year Fiero you plan to be working on... as it makes a difference!
LS4FieroGuy
Report this Post10-08-2024 01:02 AM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah ofc! It's an 88 SE.
Report this Post10-08-2024 07:09 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the front: https://fieroguruperformance.com/?page_id=1157
The springs are in the middle of the lower control arm, so 1" cut on the spring = 2" lowering of the car. You can always cut more, but can't add it back, so start with cutting 1/2 to 3/4 of the top of bottom coil with a cut off disk. Then install the cut end facing down and make sure it rests in the recessed groove in the lower control arm.
If you are running KYB shocks, they are longer than stock and with the shorter bump stop, you will want to add spacers between the shock t-bar and the lower control arm. Using 3/8" nuts as spacers works, or you can get some 1/2" tall spacers. This keeps the shock from bottoming out internally before the bump stop hits.
You can trim the stock bump stop, but Dorman 31053 is a near bolt in solution. Just need to enlarge the bolt hole in the lower control arm slightly (I think to 3/8") and it drops right in. I swapped to these on my car earlier this year.
For the rear, again start with smaller cuts and work up to the amount of lowering. The cuts have to be from the top larger diameter of the spring as the lower portion has to rest in the lower spring perch.
As an alternative, cut down front springs can work in the rear if you make a flat plate with a centering ring for the top of the spring. This will give you a stiffer spring rate (220ish vs 145).
[This message has been edited by fieroguru (edited 10-08-2024).]
LS4FieroGuy
Report this Post10-11-2024 03:18 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So how much would I have to cut the rear springs? Would I cut the rear the same as the front?
Yorgle
Report this Post10-11-2024 04:17 PM Click Here to See the Profile for YorgleSend a Private Message to YorgleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've cut springs on several cars over the years and from what I recall, there's no practical way to anticipate how much a car will drop- it's not a 1:1 ratio. I wouldn't do it if I was looking to drop more than 3/4 inch or so. Springs get stiffer the shorter they are and the more they are compressed, but generally, 1/4-1/2 a coil at a time is a safe way to to do it. Sure, it's a pain to remove, cut, reinstall, measure, repeat, but you can always cut more off- you can't add it back.
LS4FieroGuy
Report this Post10-14-2024 01:59 AM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I guess my main question is to lower the car evenly do I cut the front springs and rear springs the same amount?
Joshua Seeger
1985 Fiero GT
Report this Post10-14-2024 08:02 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe, maybe not, what people have been saying is to cut them a little at a time until you are satisfied, get the front where you like it, then get the rear where you like it, by doing several small cuts instead of one big cut.
cliffw
Total ratings: 292
Report this Post10-14-2024 07:26 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why do you want to lower your Fiero ? To fill in the wheel well / tire gap ?
[This message has been edited by cliffw (edited 10-14-2024).]
