  Broken line from Throttle Body to ERG
Broken line from Throttle Body to ERG by abitsma
Started on: 10-06-2024 02:18 AM
Replies: 4 (90 views)
Last post by: fierofool on 10-06-2024 06:43 PM
abitsma
Report this Post10-06-2024 02:18 AM Click Here to See the Profile for abitsmaSend a Private Message to abitsmaEdit/Delete MessageReply w/QuoteDirect Link to This Post
When working on the Saturday project Fiero, I accidently broke one of these lines that goes from the Throttle Body to the ERG (At least I'm pretty sure that's what it is).
Where do I find replacement hard lines for this?
I tried poking around the internet but it seemed useless.
Is this something I can get a local autoparts place to do?
Should I repair it instead?
Is there a website that has these?
Thanks guys.
Report this Post10-06-2024 02:21 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just connect the two pieces with a very short length of appropriate sized rubber hose.
It's EGR... Exhaust Gas Recirculation
Vintage-Nut
Report this Post10-06-2024 10:01 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, you can 'repair it' as noted....
Yes, however not for the four cylinder and not separately as the V6 vacuum lines are found in a kit:
Rodney Dickman's Kit
https://rodneydickman.com/a...3a2013a2bde63162dc5a
The Fiero Store Kit
https://www.fierostore.com/.../Detail.aspx?s=52389
[This message has been edited by Vintage-Nut (edited 10-06-2024).]
Total ratings: 200
Report this Post10-06-2024 11:28 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys.
The plastic lines don't really serve any purpose (above normal vacuum lines) other than to make the engine bay look a little bit less crowded, and hopefully clean it up a bit. They're molded lines, and they do look nice. but if you're just trying to get it to run nicely, you can simply replace that entire thing with a length of vacuum hose.
Total ratings: 154
Report this Post10-06-2024 06:43 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Aside from finding a rubber hose with the correct inside diameter, you can also slide a piece of shrink tubing onto the line, butt the ends together and shrink it. I've used that method on the other end of the same line and on the line from the V6 MAP sensor to the fuel pressure regulator.
