Gauge lights by Scuba_steve45
Started on : 10-07-2024 03:19 PM
Replies : 11 (150 views)
Last post by : Scuba_steve45 on 10-12-2024 03:54 PM
Oct 7th, 2024
Scuba_steve45 Member Posts: 35 From: Ohio Registered: Sep 2024
So I have a 1985 Fiero (5 speed 4 cyl) and when I turn on my parking lights to light up the gauges my left turn signal lights up on the gauge:
Does anyone know how to resolve this issue or where I should start? Thank you!
03:19 PM
87GT3800SC5SPD Member Posts: 308 From: Gig Harbor, Washington Registered: Oct 2002
What happens when you turn on the left turn signal? Does one of the gauges blink?
03:41 PM
olejoedad Member Posts: 19133 From: Clarendon Twp., MI Registered: May 2004
Check the left front parking light socket for a bad ground, it's very common for the front bulb socket to corrode.
04:17 PM
Both turn signals work completely normal.
quote Originally posted by 87GT3800SC5SPD: What happens when you turn on the left turn signal? Does one of the gauges blink?
05:33 PM
I’ll look into that and let you know. Thank you!
quote Originally posted by olejoedad: Check the left front parking light socket for a bad ground, it's very common for the front bulb socket to corrode.
05:34 PM
Oct 8th, 2024
DeathProofJonny Junior Member Posts: 2 From: USA Registered: Sep 2024
Are you using LED bulbs anywhere in the circuit?
------------------ 1986 SE 2.8 4spd 330k+ miles
05:27 AM
88Fingers Member Posts: 229 From: Burlington Ontario Canada Registered: Sep 2018
Hello There, just had the exact same issue on one of my '88 GTs. Replace the socket with one from Rock Auto or the Fiero Store. Problem solved
06:46 AM
82-T/A [At Work] Member Posts: 24330 From: Florida USA Registered: Aug 2002
quote Originally posted by Scuba_steve45: So I have a 1985 Fiero (5 speed 4 cyl) and when I turn on my parking lights to light up the gauges my left turn signal lights up on the gauge: Does anyone know how to resolve this issue or where I should start? Thank you!
Steve, quick question... are the gauges naturally that bright? ... or are you using newer bulbs, etc?
I haven't had an 85 in a long time (though my daughter has one now), and just curious if that's how it should look.
Thanks!
08:50 AM
Yes I am using led bulbs in the gauge.
quote Originally posted by DeathProofJonny: Are you using LED bulbs anywhere in the circuit?
04:13 PM
Oct 11th, 2024
quote Originally posted by 82-T/A [At Work]: Steve, quick question... are the gauges naturally that bright? ... or are you using newer bulbs, etc? I haven't had an 85 in a long time (though my daughter has one now), and just curious if that's how it should look. Thanks!
01:54 AM
Mike in Sydney Member Posts: 746 From: Meadow Flat, NSW, Australia Registered: Sep 2011
Did this happen before you installed LEDs? Do you have LEDs in the turn signals? If so, I suspect you have need a ballast resistor on the circuit. That’s what I did to resolve a similar issue.
07:50 AM
Oct 12th, 2024
I am just using the led bulbs in the gauge. This did not happen before I put the led bulbs in but I also had a different gauge when I had normal bulbs in.
quote Originally posted by Mike in Sydney: Did this happen before you installed LEDs? Do you have LEDs in the turn signals? If so, I suspect you have need a ballast resistor on the circuit. That’s what I did to resolve a similar issue.
03:54 PM
