  how to check tach filter
how to check tach filter by Wayne Renninger
Started on: 10-08-2024 02:37 PM
Replies: 2 (76 views)
Last post by: Dennis LaGrua on 10-11-2024 10:10 PM
Wayne Renninger
Report this Post10-08-2024 02:37 PM Click Here to See the Profile for Wayne RenningerSend a Private Message to Wayne RenningerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a way to check tach filter? Tach jumps all over when starting and pegs under accelaration? Or is it bad tach?
Total ratings: 200
Report this Post10-08-2024 04:20 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think the only other way is to bypass it... and see if it stops "floating," though it could be inaccurate.
Definitely sounds like a bad tach filter, not the tach though. Could also be a bad ground...
Total ratings: 329
Report this Post10-11-2024 10:10 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take it out of the circuit and replace it with a bare wire. The tach should work but better than it has been,
The filter effectively blocks high-frequency ignition noise so only clean ignition pulses are sent to the tach. If you have an extra just replace it and see,
