  Best flywheel for a 3.4 V6/60 with a 5-Speed Getrag?
Best flywheel for a 3.4 V6/60 with a 5-Speed Getrag? by 82-T/A [At Work]
Started on: 10-08-2024 04:26 PM
Replies: 15 (265 views)
Last post by: La fiera on 10-13-2024 10:09 PM
Total ratings: 200
Report this Post10-08-2024 04:26 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I'm starting to acquire parts for my 3.4 build... and I'm curious whether or not I should go with a stock 88 neutrally balanced cast steel flywheel, or if I should go with the Fidanza lightweight flywheel... or if there's an even better option?
Here's what I'll have (at the end of the day)
3.4 V6/60 F-body motor
.020 overbore DOHC pistons (9.7:1 compression)
H272 Crane Cam w/ roller rockers
WCF Stainless shorty headers and 2.5" stainless exhaust all the way back
17# injectors
(probably) EZ EFI 2.0 Controller w/ MSD 6EFI Ignition
SI Stainless Valves with Ported cyl heads
Port matched intake pieces, w/ bored throttle body and (eventually DAWG mod)
I'm shooting for 200 reliable HP.
It's going to have a 5-Speed Getrag that will (if I can get it to work), the internals for the Oldsmobile SCX gearing (3.94:1 final drive).
With all of that said... do I want a stamped steel flywheel, or do I go with the lightweight one? How is one better than the other?
I know it needs to be neutrally balanced...
Thanks!
lou_dias
Report this Post10-08-2024 05:11 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use the Fidanza flywheel. It's aluminum with the replaceable contact area. Some people say you have to use washers on the bolts but I haven't had any problems with them backing out of the crank.
Driving-wise, it's easier to stall the car shifting into 1st but it nets you more power the faster you spin it.
Report this Post10-08-2024 06:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Todd, you need to re-read your thread from five years ago. Flywheel and 5-Speed Getrag Questions
Lou, I wonder if you've not had any trouble simply because your drivetrains are probably not being used for tens of thousands of miles (before being pulled).
lou_dias
Report this Post10-08-2024 08:10 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
A fair point... But when they are used, they take a lot of abuse...
Total ratings: 200
Report this Post10-08-2024 08:25 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a plan. That old thread I posted was a lot of fun Patrick (hahahah)...
Thank Lou, I'll order one tonight.
I'm concerned about the larger bolt holes... I wonder if it's a different part number, or if there was something weird there?
I'll get new bolts for this too... we re-used the bolts (with thread-locker) for my daughter's flywheel, but that was an Iron Duke.
Total ratings: 463
Report this Post10-08-2024 10:02 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 3.4 DOHC is getting a stock V6 flywheel.
BillS
Report this Post10-09-2024 12:41 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just machined the stock 3.4 flywheel to lighten it before balancing the engine.
ericjon262
Report this Post10-10-2024 07:38 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm using the Fidanza as well, I used Ford Coyote ARP flywheel bolts, they have really big heads and distribute the clamp force over a larger area, I haven't had problems with them backing out, but the car also doesn't have a ton of miles on it. The bolts need to be shortened about .030 IIRC, or they bottom out before clamping. measure yours and be sure.
La fiera
Report this Post10-10-2024 09:53 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the same set up as well with wider hardened steel washers in between the bolts and the aluminum flywheel to give it more area of clamping force but I use blue Loctite on the threads. Reason being because I do lots of transient on/off the throttle and the on full power is longer and more repetitive than average. The washer acts as a buffer between the bolt and flywheel spreading the force over an much ample surface. The problem with aluminum flywheels is that if you don't take into account the aluminum expansion rate depending on how fast you heat it up, the gap between the flywheel and the bolt shrinks which is great but it starts to gouge or eat the aluminum over time if you don't use a washer and a gap gets created and that is when the flywheel gets loose even though the bolts are in the same place they were torqued.
Report this Post10-11-2024 03:36 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC the 3.4 DOHC engine uses a neutrally balanced flywheel for an internally balanced engine. I believe that Ed Parks may have also used them on his 3.4L P/R engine swaps.They were slightly heavier than the stock 88 Fiero flywheels but apparently they worked for that application.
lou_dias
Report this Post10-11-2024 01:42 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be careful with flywheel weights.
IIRC the pre-88 flywheels weigh 12 lbs.
88 flywheels weigh 15 lbs.
I believe this is why the 88V6 is rated for lower hp than the pre88 2.8's.
Total ratings: 200
Report this Post10-11-2024 07:45 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
For what it's worth, I watched a ton of YouTube videos, and found several websites that showed before and after dyno curves, and there seems to be a 1.5-2% increase in horsepower across the entire RPM range with a lighter flywheel (some were lighter comparatively than others). They all seemed to say the same thing though, not to expect a better quarter mile "drag time" with a lighter flywheel, but that the flywheel helps on road courses (as you guys said).
Regardless, I'm not building the car to drag race, but to enjoy the car through upshifts and downshifts.
ericjon262
Report this Post10-12-2024 12:23 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure whatever washers you are using have sharp edges removed, and were carefully inspected, but ARP's instructions explicitly state to NOT use any kind of washer under the bolt heads.
This is a documented material property, in engineering terms, it's referred to as "creep" it can occur with or without cyclic load changes.
pmbrunelle
Total ratings: 63
Report this Post10-12-2024 09:43 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don’t see why a suitable washer couldn’t be used beneath an ARP bolt.
Probably some folks used soft washers beneath a highly-tightened ARP bolt, and then when the washers creeped, customers blamed ARP for bad bolts that loosen.
Their instructions most likely originate from problem customers in the past.
ericjon262
Report this Post10-12-2024 10:43 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree, I didn't inquire as to why my Coyote bolts have heads that are as big as the washers I was going to use, so I omitted them.
La fiera
Report this Post10-13-2024 10:09 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes its very obvious! That's because the Coyote engine doesn't have an aluminum flywheel.
