  I think I hit a curb...
I think I hit a curb... by Cliff Pennock
Started on: 10-12-2024 06:52 AM
Replies: 21 (362 views)
Last post by: Patrick on 11-03-2024 04:06 PM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post10-12-2024 06:52 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
...or something.
I got my car back from the garage today, and when I was home I noticed this:
I asked the garage about it and they said the exhaust was like this when they got it. I believe them since they could have easily repaired it if they did it themselves but mostly because I remember backing up and hitting a curb a few days before I brought them my car. I have backed up into a curb before and never had any damage so this time I didn't check for any damage.
By the looks of it, It weren't the tips that hit the curb (since I see no damage there) but rather the pipe itself. So how can I straighten this? Simply try to bend it back?
Total ratings: 206
Report this Post10-12-2024 07:02 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get it on a lift to inspect the exhaust system.
Once the bent area is identified, use an oxy/acetylene torch to heat the area and a long pipe in the exhaust to bend the tips back to where they belong.
It's usually a two man job, your shop should be able to handle the job.
I've done the same thing to my car in the past.
Total ratings: 200
Report this Post10-12-2024 07:56 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
...or something.
Looks like you can kind of see where the "trumpet" on the right side has some concrete still around the exhaust opening where it might have gouged it out.
But I know... just one more thing! Is the car driving a lot better after the work?
cartercarbaficionado
Report this Post10-12-2024 12:25 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
...or something.
you could heat it but I would remove the tip and then use a nice large socket and extension to bend the muffler straight again and then work on getting the tip correct. if you didn't want gt tips I have a set of good condition formula tips somewhere
RWDPLZ
Total ratings: 305
Report this Post10-12-2024 03:24 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like the whole exhaust system is sagging down and back on the driver's side. Have to get it back up into the air to check. Hanger may have fallen off or bent.
Report this Post10-12-2024 05:54 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the driver's side tips cocked off as well? If so, I'd suspect the entire exhaust system has been twisted.
It would be helpful to see a low angle shot of the whole back of the car.
Vintage-Nut
Report this Post10-13-2024 09:50 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock:
I got the car back yesterday {Oct 11} / they also made some pictures while they were working on the car:
[This message has been edited by Vintage-Nut (edited 10-13-2024).]
Cliff Pennock
Administrator
Total ratings: 699
Report this Post10-13-2024 12:36 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good catch!
But... how the hell did that happen? Is that the weakest points? Also, When I (try to) bend it back, will there still be a big dent? And is this restricting exhaust flow much?
RWDPLZ
Total ratings: 305
Report this Post10-13-2024 02:07 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably like you said, hit a curb. I'd try laying under the car and put a C-Clamp on the wide ends and squeeze it back into shape. It's not restricting it much, but the hot tip might be burning the bumper.
Report this Post10-13-2024 03:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff, it's very difficult to imagine that you wouldn't have noticed the passenger side tips being cocked off to one side like that if it was bent that way before you dropped off your car at the shop. Yet, it's plainly obvious that the pipe was bent before the cradle was dropped. So... you didn't do it after you got the car back. I suspect someone at the shop bent it while they were maneuvering the car in the shop.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post10-13-2024 05:15 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well like I said, I remember backing up into a curb days before I brought the car to them. I didn't check for damage then (like I usually do).
jpeeler
Report this Post10-13-2024 06:09 PM Click Here to See the Profile for jpeelerSend a Private Message to jpeelerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder why the shop that did all this work for you apparently noticed something like that and didn't just go ahead and fix it as a courtesy. Or at the very least ask if you wanted it addressed.
[This message has been edited by jpeeler (edited 10-13-2024).]
Mike in Sydney
Report this Post10-13-2024 06:14 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff, at least it's an easy fix. Suggest you put the car on a lift and use an oxy-acetylene torch to heat tthe pipe in the bent area to a medium glow then pull the exhaust tip around to where it should be. You can put a broomstick or pipe in the exhaust if you need attional leverage.
I seriously doubt that you have enough of a ding to affect performance but if the dent doesn't come out enough for you, you can use a spot weld dent puller to tease out the dent. If your exhaust pipe is not too compromised by rust it should come out. I've used this method to pull out dents on crushed coolant pipes .
Cliff Pennock
Administrator
Total ratings: 699
Report this Post10-13-2024 07:15 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
They actually did quite a bit of extra work as a courtesy already. They didn't mention it because they thought I already knew it was dent.
Report this Post10-13-2024 07:27 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh... I missed that part.
The actual "dent" in the pipe is inconsequential. It's the fact that the exhaust tip is pointing way off to the side that is of concern. Besides the fact that it looks awful, you don't want a hot exhaust tip melting the bumper skin. I'm surprised the shop didn't just straighten it out, as it would've been pretty simple to do with the cradle dropped.
Total ratings: 200
Report this Post10-14-2024 03:26 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff, my opinion (having seen how they do this in body shops for frames), tie a ratchet strap to the other side of the exhaust, and snug it down, and then do exactly as RWDPLZ says. As you clamp it down tighten the strap some more to kind of force the metal back in place. It should not affect the other side of the exhaust pipe, just keep an eye on it. At least you'll be able to get it back more or less into spec.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post11-03-2024 01:50 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I think I figured out with which part I hit the curb. It wasn't the exhaust tips that caught the curb, but the exhaust clamp (tail pipe hanger). I had straightened the tips by inserting a pipe and bending it back but when I did, I noticed I could move the tip up and down without any effort. I saw that one of the clamp's bolt was bent, so I probably hit the curb with the bolt.
Problem is, that prevents me from tightening the clamp. Or loosen it for that matter. I don't have spare clamps so until I do, how can I fasten it? I don't have any room for another clamp (without hanger) I think.
Report this Post11-03-2024 03:17 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...which is exactly the reason why exhaust clamps should never be tightened in place with the bolts pointed down. I either install them pointed straight up, or if tightening them positioned that way is an issue, I then position the bolts parallel to the ground.
Cliff, I was trying to find the images I posted years ago of where I located the hangers (and clamps) near the exhaust tips on two of my Fieros... but of course, they're among the tens of thousands of missing images.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post11-03-2024 03:30 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, but these are the "official" clamps so you can't point them with the bolts up...
Report this Post11-03-2024 03:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good point... but that's one of the reasons why I relocated the exhaust tip hangers on my Fieros.
I searched my hard drive and found one of the "lost" uploaded images. This is the driver's side of my '86 GT, with the plastic wheelwell liner removed, looking towards the rear of the car. You'll notice the original factory hanger has been removed. However, due to the pipe being crushed by the original clamp, the joint is still tight.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post11-03-2024 03:56 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
But until I get myself a new set of clamps, what would be the best way to fasten the tip? Short of welding it.
Report this Post11-03-2024 04:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Until you remove/replace the broken clamp... are you just trying to prevent the exhaust tip from rotating downwards? If so, I suspect you could hold the exhaust tip in place by simply attaching a wire to it and attaching the other end somewhere to the frame above the exhaust. Sure, it's a mickey mouse repair, but it's not supposed to be permanent.
