  M17 Transmission Shift Lever and Brackets
M17 Transmission Shift Lever and Brackets by Csell2
Started on: 10-20-2024 03:15 PM
Replies: 0 (50 views)
Last post by: Csell2 on 10-20-2024 03:15 PM
Csell2
Report this Post10-20-2024 03:15 PM Click Here to See the Profile for Csell2Send a Private Message to Csell2Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello!
Long story short I've thrown an M17 V6 4 Speed into my 84 Iron Duke; and I can't get the levers and cables to work right.
And looking for pictured of how the M17 brackets are setup onto of the transmission and advice as to potentially why I can't get mine to work.
I know after 84 the lever (10030696) was replaced by the (10035025) lever, however lacking the 5025 I'm attempting to use the 0696 but I'm having no luck. The visible difference between the two is that the 0696 has 2 notches but the 5025 only has one. So I suspect this is one such issue, but didn't think that it would prevent it from working.
Any help or photos are appreciated.
