  Any links to an in-car head removal?
Any links to an in-car head removal? by jumpmonkey
Started on: 10-28-2024 06:47 PM
Replies: 10 (143 views)
Last post by: eimhear on 10-30-2024 04:17 AM
jumpmonkey
Report this Post10-28-2024 06:47 PM Click Here to See the Profile for jumpmonkeySend a Private Message to jumpmonkeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm struggling to find a post about removing the heads while the engine is still in the vehicle.
I'm replacing all gaskets from the heads up on my 85GT 2.8 and want to make sure I do it all in the correct order.
Any help is appreciated. Thanks!
Jumpmonkey
Vintage-Nut
Report this Post10-28-2024 07:37 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I rebuilt the cylinder heads without pulling the engine and to me, it's really not hard, but very time consuming.
Some well suggest removing the deck lid; I didn't....
If you can; start at Top Dead Center on the compression stroke of #1 cylinder with the distributor rotor pointing at distributor terminal #1. I suggest making alignment MARKS at the distributor base AND on the intake manifold for a timing point.
My 'best' advice is to pull the cylinder heads with the exhaust manifolds as one part; disconnect the Y-pipe and pull the cylinder heads with exhaust manifolds attached. After, remove the exhaust manifolds from the heads on the bench. Use the reverse to reinstall the heads on the block.
2.8 Head Removal by DRE Fiero
https://www.fiero.nl/forum/...manifolds%20attached
Build it up, Tear it down: Replacing V6 Head Gaskets by Falcon4
https://www.fiero.nl/forum/...070315-2-078632.html
[This message has been edited by Vintage-Nut (edited 10-29-2024).]
1985 Fiero GT
Report this Post10-28-2024 08:25 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just went through this this summer, in car head removal, didn't do a write up but it isn't too hard, had everything disassembled in one go, took longer to assemble because it was headless for a month and I forgot where all the pieces went haha, as stated, leave the exhaust manifolds on, they give a good handle, and if you are having trouble with the heads being stuck on/together to the lower intake (make sure nothing will be damaged by this, pushrods are removed, nothing's in/hanging on/over the engine etc.), crank the engine over, the compression will pop then loose, but won't throw them off or anything damaging, my 2 heads and lower intake were all stuck together to the block, doing that broke both heads loose, and the intake was left only stuck to the one head, removed as a unit, and separated later. Now's the time to do porting!
Total ratings: 200
Report this Post10-29-2024 01:06 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would say, leave the back exhaust manifold log still attached to the (forward facing) cyl head. It's likely that if it's never been removed at this point, one or more of the bolts may break off, and it'll be easier to remove them with the head off, than trying to put your arm / hand back there.
Report this Post10-29-2024 03:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
leave the back exhaust manifold log still attached to the (forward facing) cyl head. It's likely that if it's never been removed at this point, one or more of the bolts may break off...
The other advantage of leaving the exhaust manifolds in place when removing both heads, is that it would be easier to properly apply a quality penetrating oil (not regular WD-40!) to hopefully help and prevent the exhaust manifold bolts from breaking off in the heads in the first place.
Total ratings: 200
Report this Post10-29-2024 04:14 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's a really good point.
richard in nc
Report this Post10-29-2024 06:42 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
take lots of pictures first.some of my pictures saved me.
Vintage-Nut
Report this Post10-29-2024 08:34 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
richard in nc:
take lots of pictures first. some of my pictures saved me.
Big Point - take lots of pictures through the process; you never know the unforeseen ‘crises’ of Life's little emergencies and interrupt your work.......
I still have the photos of my process which I {and richard } used to remember the steps......
Total ratings: 329
Report this Post10-29-2024 09:14 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've seen guys remove the cylinder heads without taking the engine down but one guy I know actually tilted the engine cradle down to free up more space. The job is a lot of work but it can be done.
Report this Post10-29-2024 10:08 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the method I used to generate more working room when I had to drill out a couple of broken exhaust manifold bolts from the forward head of my '86 GT. Even with the added room to maneuver, it was a b!tch of a job. If I had to do it over again, I think I'd remove the head(s).
eimhear
Report this Post10-30-2024 04:17 AM Click Here to See the Profile for eimhearSend a Private Message to eimhearEdit/Delete MessageReply w/QuoteDirect Link to This Post
It can be a bit tricky, but with the right approach and steps, it can be done. Learn more here
