  Using a Pressure / Power Bleeder for the Clutch Master - Finding an Adapter That Fits
Using a Pressure / Power Bleeder for the Clutch Master - Finding an Adapter That Fits by xetura
Started on: 10-29-2024 04:28 PM
Replies: 10 (233 views)
Last post by: Ponnari on 11-12-2024 10:42 AM
xetura
Report this Post10-29-2024 04:28 PM Click Here to See the Profile for xeturaSend a Private Message to xeturaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey all. I'm looking for a pressure/power bleeder adapter for the clutch master cylinder. I attempted to make one out of an old cap, but the cap is too flexible and leaks all over the place. If there's another vehicle that uses the same cap that's stronger, I could use that to make my own. But I'd prefer one I can just order and not have to worry about it. I tried a couple off Amazon, but they don't fit. Pics of the ones that DON'T fit are attached. Thanks.
****As much as I appreciate it, I'm not interested in people posting all the different bleeding methods. I know how to do it. This is about finding a pressure bleeder cap for the Clutch.****
Report this Post10-29-2024 04:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Years ago I did just that... and it didn't leak. Just letting you know that it is possible to successfully do.
xetura
Report this Post10-29-2024 04:52 PM Click Here to See the Profile for xeturaSend a Private Message to xeturaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've seen pics of older caps and they look much sturdier than the one I have (which is newer). I'm not sure which one you used, but the newer ones are flimsy and thin.
Report this Post10-29-2024 04:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wasn't aware that there was a difference between "older" and "newer" clutch master reservoir caps. The one I used was probably an original cap from the 80's.
You did say you used an "old cap".
[This message has been edited by Patrick (edited 10-29-2024).]
Larryinkc
Report this Post10-29-2024 05:20 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some good info here, V8 Archie's clutch bleed info and other Archisms
http://www.v8archie.com/v8Archie/ToC6.htm
Report this Post10-29-2024 06:01 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used these in the past. Just need to keep the gaskets in place and regulate the air pressure to single digits.
Any more, I just bleed the manual way with a hose in a bottle.
Report this Post10-29-2024 06:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...and regulate the air pressure to single digits.
That's probably the secret to success. Back when I was still using this method to bleed the system, I just used a hand vacuum/pressure pump.
Vintage-Nut
Report this Post10-29-2024 09:26 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
To me, purging air from a hydraulic system is so easier with vacuum than pressure or the gravity method.......
larafan
Report this Post10-30-2024 09:13 AM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently bought new master and slave from Rodney Dickman along with his bleeder kits and was very simple 1 man operation per his instructions. Bench bled the master and installed. Swapped the slave and elevated the rear and used his 1-waay bleeder. Easy.
Report this Post11-02-2024 12:08 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
We've bled the clutch slave cylinders with a vacuum bleeder and have achieved good results.
Ponnari
Report this Post11-12-2024 10:42 AM Click Here to See the Profile for PonnariSend a Private Message to PonnariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi, I made my bleeders that looked like fieroguru's out of old OEM caps and left their seals in. I also had problems. Through experimenting I found that 5-7 psi worked for me. When I tried 10 or more psi I couldn't keep the caps from leaking out air. I never found any other cap that fit the clutch mc. Hope this helps, good luck, please let us know when you figure this out.
PS, forgot to mention I made my bleeder using one of those plastic containers that you pump up by hand and then press the sprayer handle that I had addaped to attach to the cap.
[This message has been edited by Ponnari (edited 11-12-2024).]
