  Where to these engine parts go ?
Where to these engine parts go ? by MERATIME
Started on: 10-31-2024 12:19 AM
Replies: 4 (162 views)
Last post by: sleek fiero on 10-31-2024 09:31 AM
MERATIME
Report this Post10-31-2024 12:19 AM Click Here to See the Profile for MERATIMESend a Private Message to MERATIMEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Howdy, I had a prior discussion about an 87 Pontiac Fiero SE 2.5L, 5 speed that had my engine rebuilt over the summer and now ready to prepare it for mounting. When they sent the engine block back, they sent back these parts not attached. Can someone tell me where these parts go on this 1987 Iron Duke ? Thanks folks!
[This message has been edited by MERATIME (edited 10-31-2024).]
Cliff Pennock
Administrator
Total ratings: 699
Report this Post10-31-2024 04:16 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alternator bracket:
CLICK FOR FULL SIZE
Alternator support:
CLICK FOR FULL SIZE
Alternator Brace (?)
CLICK FOR FULL SIZE
Compressor adjustment bracket:
CLICK FOR FULL SIZE
Engine lift bracket
CLICK FOR FULL SIZE
Total ratings: 200
Report this Post10-31-2024 07:00 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff is right for all of those... but these pictures of my daughter's 85 Fiero 2m4 SE might help (which has been outfitted with 87-88 engine parts). You'll be able to see all the other brackets, etc. Note... the little elbow bracket is for the A/C compressor.
You'll see where all the brackets go, including the ones that Cliff mentioned.
The thinner one that has a curved flap at the end, that is a belt guard which is supposed to protect against a shredded belt hitting the battery cables. You can see that in the second picture to the left of the exhaust manifold. It attaches to the waterpump.
EDIT: I think that big "loop" thing doesn't belong on a Fiero. But it looks to me like a tow hook. Usually, this is something that's screwed into the front bumper of a car that allows a tow-truck driver to cinch down a car onto a flat-bed. First example I could find...
My honest opinion, I'm serious... you're missing a lot of 87 parts and it seems they downgraded your engine to a V-belt (it should have a serpentine). You could easily buy a Fiero V6 and drop it in there, even carburate it if you didn't feel like going with fuel injection.
[This message has been edited by 82-T/A [At Work] (edited 10-31-2024).]
MERATIME
Report this Post10-31-2024 08:52 AM Click Here to See the Profile for MERATIMESend a Private Message to MERATIMEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Cliff & 82-T/A. This information is appreciated.
sleek fiero
Report this Post10-31-2024 09:31 AM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The loop is not a tow hook. It is a 12mm lift eye that the machine shop would use for handling the block during the machining and assembly process. I have a dozen different sizes in my toolbox for my work. sleek
