  Why not Aluminum heads from a lumina?
Why not Aluminum heads from a lumina? by Filben
Started on: 11-04-2024 05:17 PM
Replies: 8 (240 views)
Last post by: Dennis LaGrua on 11-05-2024 10:17 PM
Filben
Report this Post11-04-2024 05:17 PM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
So why NOT aluminum heads from a lumina? The heads will bolt on to the 3.4l V6(a very common swap because they are easier to find than the 2.8 if you need a new engine). The intake from the lumina and injectors should all plug in. These swaps are common enough on the S10 forums(and not unheard of on the f-body forums). I know you need to put the pistons from a FWD 3400 in to lower the compression ratio. But why is this not a common enough mod for the fieros? What am I missing?
Report this Post11-04-2024 07:50 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
People like the look of the Fiero intake.
1985 Fiero GT
Report this Post11-05-2024 06:22 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly, in fact I'll be taking a 3400, and putting the iron heads and Fiero intake on, it may be restrictive, but it is unique and really suits the car.
pmbrunelle
Total ratings: 63
Report this Post11-05-2024 10:01 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why not is because this is not a bolt-on install.
Fuel lines, coolant lines, air intake duct, dog bone, etc, none of this will work without custom fabrication.
If you want to do some fabrication, then have at it.
css9450
Total ratings: 86
Report this Post11-05-2024 02:58 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Lumina engine is a Gen II design and as such has the splayed pushrods that the earlier engines do not. I can't imagine that being a direct bolt-on.
pmbrunelle
Total ratings: 63
Report this Post11-05-2024 06:17 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
All GM 2.8 engines and their successors use parallel lifter bores.
In a splayed-pushrod engine, the lifters are straight, but the pushrods are crooked.
The pushrods operate crooked in the socket of the lifter.
Total ratings: 463
Report this Post11-05-2024 09:09 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it doesn't have to look "stock", you'll be waaaay ahead of the game by just swapping in a 3400 or 3500 - or even a 3900 - and do the necessary ECM swap, fabrication, and wiring to accommodate.
This is a very common swap within the Fiero community. Tons of documentation is out there. (I lust after a 3900, but have too much stuff going on, just now, to make it happen.)
css9450
Total ratings: 86
Report this Post11-05-2024 10:13 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I wondered about that. Thanks for the clarification!
Report this Post11-05-2024 10:17 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are my thoughts as well. Why try to reinvent the wheel when there are many proven solutions out there to power improvement. The LZ9 3900 V6 engine will provide 240 hp and 240 lb⋅ft (325 N⋅m) of torque stock. That's what the supercharged 3800SC series II engines provided but the 3900 has an amazing flat torque curve all the way out to the redline. Lots of swaps have been done with that engine. Just look on You Tube and here in the archives,
