With the 3800SC you only need a 3" intake. I mig welded 3" flanges on the intake and exit of the OEM filter can and attached 3" silicon elbow to the TB and used a 3" elbow at the bottom of the filter can and then to a 3" aluminum pipe and out to a modified side scoop. It does fit OK.
My engine currently runs the LS1 MAF that is 75 mm or 2.95". With the MAF screen it probably cuts the space down 25% so I believe that a 3" intake system flow covers it.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 11-11-2024).]
