  3800SC PCM reprogramming services?
3800SC PCM reprogramming services? by Tarpan31
Started on: 11-16-2024 10:44 PM
Replies: 7 (111 views)
Last post by: Dennis LaGrua on 11-18-2024 03:50 PM
Tarpan31
Report this Post11-16-2024 10:44 PM Click Here to See the Profile for Tarpan31Send a Private Message to Tarpan31Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
I am in the process of a 3800SC swap and am going to need a PCM soon. I am planning to snag a harness and a PCM from a yard near me, and am going to do the harness wiring work. I have done an LS swap on something else in the past so the wiring is not an issue, but for that I just sent my PCM to a dude and he flashed it for me for like 50$. I know I can use HP Tuners and stuff but the investment cost of that seems a bit higher for what I am looking for since its pretty much stock aside from having the 3800SC.
Is there someone around that does PCM reprogramming and will do a flash that essentially all stock with VATS gone? Or does anyone sell reprogrammed PCMs? I am also not opposed to buying an already complete harness if one shows up at a decent price.
Thanks!
Total ratings: 329
Report this Post11-17-2024 03:35 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Tarpan31:
Hi,
Thanks!
ZZ Performance is the best at reprogramming the 3800 PCM but if you just want the VATS turned off thats a simple flick of a couple of switches on the program. Anyone with an HP Tuners editor can get that done. Joe Welch (olejoedad) can build you a very neat and functional 3800 swap harness. His work is very good.
Total ratings: 259
Report this Post11-17-2024 09:39 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.gmtuners.com/
Ryan has done a lot of 3800 tuning in person and mail order.
cliffw
Total ratings: 294
Report this Post11-17-2024 10:17 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did not know that, thanks.
Total ratings: 206
Report this Post11-17-2024 03:24 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ryan Gick at gmtuners.
I trust no one else to tune my swaps.
Tarpan31
Report this Post11-17-2024 05:27 PM Click Here to See the Profile for Tarpan31Send a Private Message to Tarpan31Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you all so much for the info! I will reach out to Ryan for my tune. olejoedad, sending you a PM for some more info on a possible harness.
Total ratings: 206
Report this Post11-18-2024 09:16 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the nice words, Dennis.
I need to tell you that ZZ Performance tunes for a Fiero swap leave a lot to be desired. Their tunes for the FWD applications are very good, but every ZZP tune in a Fiero that we have had thru the shop were not correct.
Total ratings: 329
Report this Post11-18-2024 03:50 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I always did all my own tuning and have never used ZZP . ZZP has had more experience with the 3800 than just about any place around so I made the assumption that they should be the experts. My tunes are specific to the engine, vehicle and with so many variables it becomes a custom job. When I did them in the past we did road scans, saved the results and made changes where improvements were required. Actually WOT was the easiest as it uses a fixed fueling table. We charted the fueling mixtures per RPM and MAP readings preferably with a wideband and related that to performance but you really need a dyno to optimize horsepower with a tune. The OP just wanted to shut off the VAX. That's three changes and a 10 minute job.
