  Ignition return spring
Ignition return spring by Haggerty
Started on: 11-17-2024 07:39 PM
Replies: 4 (93 views)
Last post by: Vintage-Nut on 11-22-2024 11:05 PM
Haggerty
Report this Post11-17-2024 07:39 PM Click Here to See the Profile for HaggertySend a Private Message to HaggertyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any good resources that show how this spring is supposed to go back on? I got a little ambitious thinking I was going to remove enough to get to the upper two torx bolts that need tightening. Assumed it would be common sense putting it back on.
Haggerty
Report this Post11-17-2024 07:52 PM Click Here to See the Profile for HaggertySend a Private Message to HaggertyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was making it harder than it needed to be. This appears to be the proper or good enough method, loop around the pushrod and the other portion in the black rotating piece, key is returning after ignition.
Total ratings: 200
Report this Post11-18-2024 08:07 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ah man, I haven't dug into this yet, but I know I'm going to have to. Thanks for posting pictures of this.
Electrathon
Total ratings: 254
Report this Post11-22-2024 10:22 PM Click Here to See the Profile for ElectrathonClick Here to visit Electrathon's HomePageSend a Private Message to ElectrathonEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are 4 bolts that need to be tightened. You need to pull the two pivot pins on the side of the steering column. There is a special tool needed.
Vintage-Nut
Report this Post11-22-2024 11:05 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perhaps this link by Jazzman with photos will help ...
Inside the GM Tilt Steering Column
https://www.crankshaftcoali...ing_Rack_Rebuild.pdf
See page 34
[This message has been edited by Vintage-Nut (edited 11-22-2024).]
