  Fiero amplifier to sub woofer question
Fiero amplifier to sub woofer question by cam-a-lot
Started on: 11-17-2024 08:21 PM
Replies: 3 (51 views)
Last post by: 82-T/A [At Work] on 11-18-2024 08:05 AM
cam-a-lot
Total ratings: 99
Report this Post11-17-2024 08:21 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello
My car has the factory sub, but I have replaced the head unit with a Monsoon one with built in Bluetooth
Would like to run the factory sub woofer, but I think this requires a dediated amp. Don't need anything crazy since it is just one speaker
Any suggesions on an appropriate amp? Not sure if the Monsoon unit has any kind of built in "crossover" effect so that I am not pumping treble into the amp
Sorry- I I know nothing about car audio...
Suggestions?
1985 Fiero GT
Report this Post11-17-2024 08:57 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Factory subwoofer has a factory amp in the passenger side carpet on the center shift console, with aftermarket head unit, you will need to run seperate power cable as the original radio provides a high power feed that aftermarket units don't, but all other wires should hook up and function, and there is a bass slider by the dome lights to control basic equalisation.
[This message has been edited by 1985 Fiero GT (edited 11-17-2024).]
Total ratings: 259
Report this Post11-18-2024 07:06 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can also get one of many different factory amps from other vehicles. When I added the factory sub housing with a larger sub to my car, I used a "dealer option" kicker 100W amplifier that drives the subwoofer in the Jeep SRT8. It is a small amp with a built in low pass filter which worked well.
Total ratings: 200
Report this Post11-18-2024 08:05 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by cam-a-lot:
Hello
Suggestions?
You'll probably want to replace the subwoofer speaker as well... if it hasn't already been replaced, then it likely has a dry-rotten cone and probably will sound like garbage with a good head unit.
