  Why is the Camaro/firebird 3.4 the preferred 3.4 upgrade engine? Will others work?
Why is the Camaro/firebird 3.4 the preferred 3.4 upgrade engine? Will others work? by phils88GT
Started on: 11-19-2024 07:56 PM
Replies: 15 (382 views)
Last post by: 82-T/A [At Work] on 11-23-2024 09:33 AM
phils88GT
Report this Post11-19-2024 07:56 PM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have read where the 94-97 Camaro 3.4 is the preferred swap engine. Why is this? What makes it more difficult or expensive or whatever to use any other GM FWD 3.4, like from a Buick or Pontiac, etc?
Thanks all!
pmbrunelle
Total ratings: 63
Report this Post11-19-2024 08:01 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The F-body 3.4 uses the same cylinder heads as the Fiero 2.8, therefore the F-body 3.4 is nearly a bolt-on swap into a V6 Fiero. Hence, it is commonly preferred.
Other engines (with different cylinder heads) of the GM 60°V6 family can be made to work, but they are less bolt-on.
It is the 93-95 F-body 3.4, not 94-97.
[This message has been edited by pmbrunelle (edited 11-19-2024).]
Report this Post11-19-2024 09:01 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another reason that many Fiero owners like the 3.4L P/R engine is because it is an easy bolt in swap but when installed the appearance is identical to the 2.8L. In states like California you won't pass inspections with a swap of different engine. The 3.4L looks stock and with a CAT it passes through. For other engine swaps you need to go though a process of getting your swap approved and it must be certified to meet CARB standards that isn't easy. .
1985 Fiero GT
Report this Post11-20-2024 07:56 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A direct swap of a 3400sfi (the 3rd Gen 60* v6 3.4 found in many gm cars) is more complicated than the Firebird 3.4, for stock looks, you can reuse your old Fiero heads (bolt on), but unless you want to drive with 7-or-so:1 compression, pistons will also need to be swapped, as for the block itself, it requires a little clearanceing on the oil pan to make it work, similar work to the Firebird as that requires starter holes drilled, people choose the Firebird engine as it looks completely stock, and only needs one "modification" to work (starter holes). If you want low compression for a turbo or supercharger, and stock looks, the 3400 is stronger, and equally easy of a swap, but if you want normal compression, Firebird motor already has the right pistons. If you want higher compression, the pistons from the 3.4tdc (dohc engine) will work in any of the 3.4s, so you might as well start with the stronger 3400 if you have to change pistons anyhow.
Total ratings: 200
Report this Post11-20-2024 08:26 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
To add to what everyone has said... it's mostly for getting more horsepower, while maintaining identical appearance.
It's not the BEST option though if you want more power. Personally, the 3400 series motors are awesome... and the cyl head technology is vastly improved.
The 3400 in the minivan produced 185 hp at 5200 rpm and 210 lb⋅ft of torque at 4000 rpm
The 3.4L in the 93-95 F-body produced 160 hp at 4,600 rpm and 200 lb⋅ft at 3,600 rpm
Basic engine upgrades will get you 190hp with the 3.4 cast iron engine... port-matching, better exhaust manifolds, and a new camshaft... but you will be limited by the Fiero's intake unless you modify the throttle body neck (constricts air).
All those same upgrades to the 3400 motor though, from what I've read of others on here, allows you to get more power with less effort.
I'm in the process of building a 3.4 V6/60 ... well, I have all the parts, I just haven't assembled any of it yet. But I'm going with higher compression 9.7:1 pistons, a hotter cam, and a bunch of other stuff. My goal is ~200hp. I just want a Fiero that runs mid-14s all day long without too much effort... so I can relive my teenage years, while not getting destroyed by electric Amazon delivery trucks.
EDIT: Are you having a hard time finding one? Just curious... I'm interested to know the background for your question. Are you considering an engine swap and just looking for options? There are a bunch of people here who have done a few different types of V6 engine swaps... they can probably tell you why they made the decision they did, versus something else.
[This message has been edited by 82-T/A [At Work] (edited 11-20-2024).]
phils88GT
Report this Post11-20-2024 09:28 AM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
To be honest, how the engine looks compared to the original I really couldn’t care less about. I want more power as the 2.8 is so anemic. I would like to actually build a 3.4 that is capable of handling some boost, nothing really crazy, maybe 12-15 pounds or so. Is this achievable with the 3.4? Is there an aftermarket out there for the 3.4?
Thanks
sleek fiero
Report this Post11-20-2024 10:39 AM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Google WOT Tech . Wide open throttle tech have a lot of 60 degree parts and info. sleek
1985 Fiero GT
Report this Post11-20-2024 12:39 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
If you don't care how the engine looks, do the 3400sfi, heads intake and all, instant 40ish hp gain with no mods. It will be hard to lower the compression for much boost, so you might be limited on that end, I'm no expert on compression ratio to safe boost. The 3400sfi had a stronger bottom end, roller valve train, and a much better head/intake design for more power potential over the 3.4 Firebird or the Fiero 2.8.
Total ratings: 463
Report this Post11-21-2024 10:09 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I lust after a 3900. (LZ9, LGD, or similar). Same basic architecture as the 2.8, but with 25 years of evolution. Will nearly bolt straight in. 240 HP right out of the box.
(The Fiero heads and intake will not bolt on, but that's not an issue to me.)
Probably will do away with the VVT, and install the equivalent of a Crane 272 cam. Or maybe a bit larger.
I'm told (you know how that goes) that something like that ought to be worth ~280, without boost. I'm guessing more than that, but that guess is being pulled out of a "dark place".
It was recommended to try to find a "non-emissions" cam that would work with the VVT, but I'm pretty sure that doesn't exist, in today's world.
Anyway... I'm babbling. Please carry on.
[This message has been edited by Raydar (edited 11-21-2024).]
phils88GT
Report this Post11-21-2024 12:40 PM Click Here to See the Profile for phils88GTSend a Private Message to phils88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What cars did the 3900 come in?
What cars did the 3400 SFI come in?
Report this Post11-21-2024 01:23 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forget horsepower, you always need to look at torque, and the torque curve.
cvxjet
Report this Post11-21-2024 01:47 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another good engine is the LV3 90* V6...it is a 4300 but built using the LS/LT technology and is all aluminum, so weighs only 300 lbs vs the 2.8 that weighs 370 lbs....it is a torque-monster with 330 lb/ft- and has 285 hp @ 5300....and a very broad torque-curve.
Total ratings: 463
Report this Post11-21-2024 09:48 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
G6, Malibu, Impala, and others on the same platform. Some minivans, too.
Look (on the RPO sticker) for LZ9, or LGD. (LGD is the flex-fuel version of the LZ9)
Avoid the LZ8. It has cylinder deactivation, and is lots more trouble than it's worth, according to the comments of a previous owner.
The cool thing about the VVT engines is that the torque curve jumps up at very low RPMs, and stays that way through much of the range.
There is also a VVT 3.5, that came in mostly the same vehicles. The LZ4 or (flex fuel) LZE. 220 HP, and a similar torque curve.
I had one in a G6, and thought it would make a great swap into a Fiero. But I ended up selling the car.
The VVT 3.5 is a de-stroked 3900.
La fiera
Report this Post11-21-2024 11:23 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/zYvWZYW6iHc?si=q1VT-_Q6UxC0e7J1
Like mentioned the 4.3L LV3 is a good swap like you can see how the experts Mr. Holdener helped by the renown BTR team can do with this big V6 engine. The L32 3.4L V6 all iron doesn't come even close!
La fiera
Report this Post11-22-2024 09:32 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
How about if you can do the same for the L32 but without the help of the experts!!!!? Trying more unconventional ways and ruling out turbos, just NA like the almighty LV3 4300 V6 Holdener and BTR fusion did on the video?
This LV3 with direct injection, long tube headers, BTR Trinity intake manifold, 11.00:1 compression ratio and 220 big BTR cam in this video made 430hp & 369lbs/ft at the flywheel. That equates to 100hp per liter and 1.41 lbs/ft per cube. That's with no alternator, water pump, Power steering, mufflers, or catalytic convertors, and with experts and an entire engineering firm behind it, E85; basically uncorked.
How would a L32 with the same privileges would measure to this big block V6? (spelling)
[This message has been edited by La fiera (edited 11-24-2024).]
Total ratings: 200
Report this Post11-23-2024 09:33 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with others... if the aesthetic doesn't matter to you... then you can pretty much go with whatever works for you. Like La Fiera and some of the others have said, the 3400 / 3500 motors will drop in using all the same motor mounts, and transmissions.
There's still other things you need to account for... such as the torque-strut mount (needs to be fabricated, but not hard), the wiring and ECM (do you go aftermarket or go stock), NOT hard... but cooling and exhaust are another thing.
The only word of caution I have is... if you go down that route, make sure you have everything planned out and purchased before you begin the swap. We've seen so many times on here that someone starts an engine swap by removing the old motor first, and then buying the parts and building it out... only to either lose interest or there's a life event or something... and the whole thing ends up in the junkyard.
