  Wiring - What is Supposed to be Plugged Into this Connection
Wiring - What is Supposed to be Plugged Into this Connection by rebeck02
Started on: 11-20-2024 04:25 PM
Replies: 15 (244 views)
Last post by: cvxjet on 11-24-2024 01:45 PM
rebeck02
Report this Post11-20-2024 04:25 PM Click Here to See the Profile for rebeck02Send a Private Message to rebeck02Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi All,
I have an 88 GT, V-6, 5-speed. If you can let me know what is supposed to plugged into the connection in the attached pictures, I sure would appreciate your help.
Thank you.
reb
Kameirocco
Report this Post11-20-2024 04:38 PM Click Here to See the Profile for KameiroccoSend a Private Message to KameiroccoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi! I'm not seeing any photos
rebeck02
Report this Post11-20-2024 09:01 PM Click Here to See the Profile for rebeck02Send a Private Message to rebeck02Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sorry all. I thought I loaded them, but I think I wiped out the links. Hopefully you all can see them here:
Thank you.
reb
Report this Post11-20-2024 09:08 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Isn't that a lamp socket?
Vintage-Nut
Report this Post11-20-2024 11:07 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
rebeck02
Report this Post11-21-2024 06:07 PM Click Here to See the Profile for rebeck02Send a Private Message to rebeck02Edit/Delete MessageReply w/QuoteDirect Link to This Post
Son of A Gun! How about that one. Simple. Thank you! reb
Romsk
Report this Post11-21-2024 06:19 PM Click Here to See the Profile for RomskClick Here to visit Romsk's HomePageSend a Private Message to RomskEdit/Delete MessageReply w/QuoteDirect Link to This Post
I concur, that is the bracket that holds the courtesy lamp and socket for the front trunk compartment.
Some people like to mount the socket for the bulb pointing up, but I think it is designed for bulb pointing down.
[This message has been edited by Romsk (edited 11-21-2024).]
Report this Post11-21-2024 07:45 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, bulb down.
The underside of the wings on the bracket can be covered with aluminium tape or painted silver for better lighting of the front compartment..
sleek fiero
Report this Post11-21-2024 08:45 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
sorry to bump but what are the two relays in the picture for? I think the one closest to the light bracket is for the heater fan but the one in the left of the photo. thanks sleek
Vintage-Nut
Report this Post11-21-2024 09:12 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
sleek fiero
Report this Post11-21-2024 10:37 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks Vintage. seeing how i've deleted my ac I can use that relay to run my new brake booster vacuum pump. thanks again sleek
Report this Post11-22-2024 01:24 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
As a side note, that Frunk light only illuminates if the parking or headlights are turned on.
Joe, I like the idea of using aluminum tape to create a reflector. I've been Fiero-ing for thirty-one years and have never heard that.
Report this Post11-22-2024 03:38 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've done that on my Fieros since I my first one in 95. It really brightens up the frunk area.
Total ratings: 200
Report this Post11-22-2024 09:05 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Oddly enough, not all Fieros came with the underhood light... it was an option.
Some Fieros didn't come with the light in the rear trunk either. It came with a solid (not clear) grey or beige plastic cap in place of where the light went, and just an empty hole where the switch would go.
It was something I thought was always kind of cool about the Fiero. If you wanted to... you could literally get the Fiero totally stripped down... like, they even had a block-off plate for the radio. I had a 1985 Fiero 2m4 SE back in 1997 that I got for $250 from a local auction, it had no options, except a sunroof, and an AM radio. I kept the AM radio because it was so weird to me... no FM... just AM.
Report this Post11-24-2024 09:48 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was something I thought was always kind of cool about the Fiero. If you wanted to... you could literally get the Fiero totally stripped down... .
I had an 88 Coupe that had ZERO options when it left the dealer. The aforementioned trunk light block off plate, radio block off plate, no AC, no Cruise, no Sunroof. Not even an antenna. No nothing.
The owners later had an aftermarket AC and an AM radio installed. Front speakers only.
cvxjet
Report this Post11-24-2024 01:45 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
l ordered my '85 SE V6 with (Obviously) the V6, and also the handling suspension, second-level radio/cassette player, and the light option- but nothing else...it only weighed 2580 w/ half tank of gas- and was very fast.
The under-hood lamps were really poorly thought out; The frunk one only came on when the headlights were on- and they lit up the whole area better than that little lamp. The rear trunk one shines right in your face- should have mounted it on the back-side of the trunk....
