  Early One wire Early Headlight Motor Gen 2 Conversion.
Early One wire Early Headlight Motor Gen 2 Conversion. by Dennis LaGrua
Started on: 11-20-2024 11:13 PM
Replies: 12 (170 views)
Last post by: Dennis LaGrua on 11-23-2024 02:55 PM
Total ratings: 329
Report this Post11-20-2024 11:13 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just noticed that headlight motor conversion kits are available for the early Corvettes that originally used vacuum motors to raise the headlights. The mechanism uses the common headlight Gen II motors used on the 87-88 Fieros and Firebirds of the same period but with a very different lift mechanism. . While the Corvette upgrade mechanical mechanism is very different from that used on the Fiero, the electrical control of the motors on this system is done with only one relay and one wire. If it works on Corvettes this kit should be capable of controlling the same headlight Gen II headlight motors on a Fiero. Then in theory the one relay one wire system should work on the Fiero. More research is needed on this but if we can crack the wiring we should be able to use the same electrical hookup to install Gen 2 motors to work in the 84-86 Fieros. Hopefully some of the tech minds on this forum can chime in with their opinion..
[This message has been edited by Dennis LaGrua (edited 11-20-2024).]
Report this Post11-21-2024 02:22 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very interesting!
Dukesterpro
Report this Post11-21-2024 03:15 PM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ive been selfishly hogging my own custom headlight controller. Both my 86 and 84 have it now. I will look into the corvette one. Get you guys some answers
Dukesterpro
Report this Post11-21-2024 03:17 PM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dukesterpro
Member since Aug 2022
Limit switches as far as I can tell. They use a reversing relay that has its ground switched by limit switches in the gear box of the headlight motor assembly. This would only work if the gear box worked with our cars. Id be more interested in faster headlights, similar to the miatas
Total ratings: 329
Report this Post11-21-2024 03:54 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would assume that the attached gearbox uses limit switches, but a current sensing circuit might also be used to shut down the motors off at the end of travel. We would need to see the physical unit to see exactly how motor function is accomplished and measure the motion control.
Total ratings: 329
Report this Post11-21-2024 04:57 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2000
AFAIK, the Corvette conversion motors are exactly the same as the GEN II motors but I do see a need for a limit switch or a current sensing circuit to shut the motors off the end of travel. If there is a gear box attached to each motor (likely) then the travel of the mechanism must be altered to the travel length of the Fiero headlight units.
Dukesterpro
Report this Post11-21-2024 06:27 PM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well hang on Dennis, GEN II motors do in fact use a inline current sensor to operate. Its how they are able to detect obstructions. Thats how my box works aswell. The problem is, this doesnt offer anything to fix the actual problem of shortage of control boxes
Total ratings: 329
Report this Post11-22-2024 03:08 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well hang on Dennis, GEN II motors do in fact use a inline current sensor to operate. Its how they are able to detect obstructions. Thats how my box works as well. The problem is, this doesnt offer anything to fix the actual problem of shortage of control boxes
If you are talking about the Corvette headlight motor conversion I do not see that it uses the GM headlight motor control module. From appearance all I can see is one relay and the "side box" on the motors that probably contains limit switches. Isn't the Gen II control just determined by polarity or reversing it? Obstruction protection can just be applied with a fuse. We've really need to see this system for further details.
Total ratings: 206
Report this Post11-22-2024 03:32 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
As there are no limit switches incorporated into the Gen 2 headlight motors, is the "side box" you reference mounted to the mechanism or the linkage?
Mike in Sydney
Report this Post11-23-2024 02:34 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, Duke. When you say shortage of control boxes, are you talking about the headlight control module on the ‘87 & ‘88 models? If so, I’m using an after-market headlight module for a C4 Corvette. Works perfectly on my ‘86 SE that’s been retrofitted with a Gen 2 headlight system. Also using it on my ‘86 GT that’s also been retrofitted with the same Gen 2 system.
Total ratings: 329
Report this Post11-23-2024 01:27 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Corvette Headlight upgrade kit contains no GM module. All I see is a relay, perhaps a DPDT. Take a look:
[This message has been edited by Dennis LaGrua (edited 11-23-2024).]
Total ratings: 206
Report this Post11-23-2024 02:03 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would think that the switches in the round housing would need adjustment to match the rotational needs of the Fiero headlight linkage, but it might work on a Fiero, if the switch housing fits the Fiero headlight mounting/ lift bracket.
Total ratings: 329
Report this Post11-23-2024 02:55 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agree on all but my interest in this kit has to do with convincing the manufacturer (or modifying the mechanical interface) to end up with something that would work on the early Fiero headlight system. Right now we do not know the lift ratio/travel of the linkage, and the shut off points on the Corvette conversion system. . I believe the rotational capability of the Fiero and motors used in this kit may be the same so all we do know is that the GM Headlight module is not used on this system. If we replace the lift arm with the Fiero component and adjust the limit switches this kit may work but since we have not seen it we really don't know more at this point.
