  Torque Question: Outer Tie Rod to the Steering Knuckle {FSM Has Two Different Spec's}
Torque Question: Outer Tie Rod to the Steering Knuckle {FSM Has Two Different Spec's} by Vintage-Nut
Started on: 11-21-2024 04:29 PM
Replies: 4 (68 views)
Last post by: Raydar on 11-22-2024 02:04 PM
Vintage-Nut
Report this Post11-21-2024 04:29 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm Confused.....
The '88 Factory Service Manual has two different Torque Spec's for the Outer Tie Rod to the Steering Knuckle.
I hope that the pros / experts can 'steer' me straight.....
The Torque in the 'Rack & Pinion' Section shows 40 ft/lbs
The Torque in the 'Front Suspension' Section shows 15 ft/lbs + ½ turn
sleek fiero
Report this Post11-21-2024 05:51 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe what they are telling you is minimum 15 plus what you need to insert cotter pin. if you did 40 plus what you need to alein cotter pin it would be too much. sleek
Total ratings: 259
Report this Post11-21-2024 07:16 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have a deflecting bar torque wrench, you can see if they result in the same reading.
15ft-lbs + 180 degrees might get you 40 ft-lbs.
Vintage-Nut
Report this Post11-22-2024 11:54 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys for the remarks and ideas....
All of my torque wrenches are 'Click' type
I believe the best plan is:
*Set my torque wrench at 15 ft/lbs and tighten the connection
*Mark the nut so I can measure ½ turn {180-degrees}
*Set my torque wrench at 30 ft/lbs and tighten the connection
*Measure the nut rotation movement
*Set my torque wrench at 40 ft/lbs
*Slowly creep on the 40 ft/lbs setting by stopping often to measure nut rotation movement and the cotter pin alignment
Thanks again,
VN
Total ratings: 460
Report this Post11-22-2024 02:04 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't hesitate to use either spec. Tie rod bolts are a friction fit, anyway.
When I did head bolts on our Honda V6 (long story) the spec (IIRC) was, tightening in sequence, 35 lb.ft., plus 90 degrees, plus 90 degrees, plus an additional 90 degrees for used head bolts. (Don't quote me on these exact specs, but it was similar.)
I think the "x plus however many degrees" removes a bit of inconsistency at the tighter end of the scale, due to variations in thread cleanliness, lubrication of the fastener, etc.
[This message has been edited by Raydar (edited 11-22-2024).]
