  Tcc trouble
Tcc trouble by Gizmo0816
Started on: 11-22-2024 05:42 PM
Replies: 4 (85 views)
Last post by: Gizmo0816 on 11-25-2024 05:01 PM
Gizmo0816
Report this Post11-22-2024 05:42 PM Click Here to See the Profile for Gizmo0816Send a Private Message to Gizmo0816Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just replaced the tcc solenoid and it worked without issue for about a total of probably 30 miles or so then one of the old issues resurfaced.
When your going at exactly 35 on the speedo you can feel it engage, but it causes the car to surge, like it didn't fully engage, give it a little more gas it'll engage or hit the brake just enough to trigger the stop, then let go and it'll correctly engage.
It only does that at 35, even just going 40 I can feel it engage and it works fine. It has no trouble disengaging and isn't causing the vehicle to stall or dip in rpms when coming to a stop.
Why would it do that?
Vintage-Nut
Report this Post11-22-2024 06:16 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
TCC solenoid replacement? by broderp
https://www.fiero.nl/forum/Forum2/HTML/133268.html
lateFormula:
I would recommend that you replace the 3rd gear switch while you are in there, as it is part of the TCC circuit.
TCC solenoid installation tips by jetman
https://www.fiero.nl/forum/...050119-2-055302.html
[This message has been edited by Vintage-Nut (edited 11-22-2024).]
Gizmo0816
Report this Post11-22-2024 07:22 PM Click Here to See the Profile for Gizmo0816Send a Private Message to Gizmo0816Edit/Delete MessageReply w/QuoteDirect Link to This Post
So the 3rd gear switch could possibly cause that? The brake is working I know that.
I don't exactly understand what it does.
[This message has been edited by Gizmo0816 (edited 11-22-2024).]
Gizmo0816
Report this Post11-25-2024 04:59 PM Click Here to See the Profile for Gizmo0816Send a Private Message to Gizmo0816Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got it backwards, it isn't disengaging if it engages at 35 - 40 which is causing the stutter when I'm trying to accelerate. Is that definitely the third pressure switch failing to inform the tcc solenoid or something?
I don't feel like taking an engine mount off again unless I have too. Super easy to put on, kinda a pain to take off. Which surprised me, usually it's the opposite.
[This message has been edited by Gizmo0816 (edited 11-25-2024).]
Gizmo0816
Report this Post11-25-2024 05:01 PM Click Here to See the Profile for Gizmo0816Send a Private Message to Gizmo0816Edit/Delete MessageReply w/QuoteDirect Link to This Post
Gizmo0816
Member since Jul 2024
It does disengage after it passes 40 or you do one of the two things I said earlier.
