  Trunk latch alternative
Trunk latch alternative by Josh86gt
Started on: 11-22-2024 06:56 PM
Replies: 9 (140 views)
Last post by: Josh86gt on 11-22-2024 11:21 PM
Josh86gt
Report this Post11-22-2024 06:56 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 86 GT but the only replacement I can find for is $208
I was wondering if instead of that one I could use this
It looks pretty much the same but doesn't stick out quite as much I was wondering if the cheaper one would work
Vintage-Nut
Report this Post11-22-2024 07:55 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the correct part (#) for the fastback trunk lock cylinder? by Cliff Pennock
https://www.fiero.nl/forum/Forum1/HTML/100672.html
Cliff Pennock:
I was able to simply replace the old cylinder with the cylinder of the notchback lock. Took a bit of Dremel work to get the old cylinder out, but the new cylinders fits and works perfectly.
Report this Post11-22-2024 07:59 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There may be a difference (I'm not 100% sure) between the trunk lock cylinder used for a fastback Fiero as opposed to a notchback Fiero. Hopefully someone here can fill in the details.
Josh86gt
Report this Post11-22-2024 08:12 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine looks like this "the 208$ one" and I'm wondering if the other thinner one would work the only difference that I know of is that the part that sticks out is not quite as long it doesn't look like it would be an issue but I'm just not sure
Vintage-Nut
Report this Post11-22-2024 09:30 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
See GM 12398669 on eBay
https://www.ebay.com/itm/315861791508?
https://www.ebay.com/itm/315443691861?
[This message has been edited by Vintage-Nut (edited 11-22-2024).]
Josh86gt
Report this Post11-22-2024 09:37 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like it
[This message has been edited by Josh86gt (edited 11-22-2024).]
Vintage-Nut
Report this Post11-22-2024 10:11 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
As yes, read Cliff's thread {in the link above} which shows the notchback trunk lock cylinder part numbers which won't fit the fastback.
Electrathon
Total ratings: 254
Report this Post11-22-2024 10:34 PM Click Here to See the Profile for ElectrathonClick Here to visit Electrathon's HomePageSend a Private Message to ElectrathonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure what is wrong with yours but if I am remembering correctly you can just use the housing you have and the inner part ( that the key slides into) from the new one. Usually you can just recode the one you have unless someone destroyed it by driving a screwdriver into it.
Vintage-Nut
Report this Post11-22-2024 10:49 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Electrathon:
you can just use the housing you have and the inner part (that the key slides into) from the new one.
'That' what Cliff did....
Josh86gt
Report this Post11-22-2024 11:21 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found a solution no need for more input thank you everyone for your help
