  F23 Shifter Brackets or LONG shift cables
F23 Shifter Brackets or LONG shift cables by Kameirocco
Started on: 11-26-2024 05:00 PM
Replies: 2 (67 views)
Last post by: Kameirocco on 11-26-2024 06:33 PM
Kameirocco
Report this Post11-26-2024 05:00 PM Click Here to See the Profile for KameiroccoSend a Private Message to KameiroccoEdit/Delete MessageReply w/QuoteDirect Link to This Post
i searched, but can't find much.... have a feeling this has been gone over a few times, so i apologize.
for the F23 transmission... If i dont use the shifter correction, i've read that i can just use longer cables and this is where my questions lie at.
1) what size cables are needed?
2) for the cables, where do i go to order them?
3) for the cables themselves, what do the ends look like?
4) were the shifter assemblies all the same in the passenger compartment? (the shifter itself)
1985 Fiero GT
Report this Post11-26-2024 06:07 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
1, no idea, I would recommend manually measuring it
2, look up California push pull, they make good cables
3, if you talk to the people at California push pull, just say you want Fiero f23 cables, they know the correct ends, you specify the length, measure, route then where you want, just know the longer they are, the more vague they will feel and the higher the effort, one give benefit if the shift correction kit
4 the assemblies are not all the same, but they all will work for the f23 with some modification for the 4 speed assembly (removing the reverse lockout and rewiring the reverse light switch)
Arrow for 1 is the direction cables are coming from the cabin, straight at the shifter (hole on right side) arrow 2 is the direction the cables are mounted in the factory setup, so to use that, you would have to go all the way around, long long cables with several bends, not great, I also think that the shift function would be reversed (2 4 R on top, 1 3 5 on bottom) with no correction
[This message has been edited by 1985 Fiero GT (edited 11-26-2024).]
Kameirocco
Report this Post11-26-2024 06:33 PM Click Here to See the Profile for KameiroccoSend a Private Message to KameiroccoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you much!
and now that i think about it, i think you're right with everything being flipflopped. Man, this rear engine thing messes withn my head sometimes!
