  EGR
EGR by LS4FieroGuy
Started on: 11-29-2024 09:16 PM
Replies: 6 (137 views)
Last post by: jelly2m8 on 12-01-2024 01:44 AM
LS4FieroGuy
Report this Post11-29-2024 09:16 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey all I'm just wondering how hard it would be to remove the EGR completely and what I would gain/loose. It's a 1988 2.5.
Joshua Seeger
Total ratings: 463
Report this Post11-29-2024 09:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are you hoping to gain by removing it?
Total ratings: 200
Report this Post11-29-2024 10:33 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
You won't really gain any power since I don't think it's being used at wide open throttle... but you won't have to clean your intake as often. The only thing to consider though is that the ECM expects it to be there, so it's been programmed to account for it.
You'll want a block-off plate. This one looks like it will fit (meant for something else), but double check... don't take my word for it:
https://halferlandperforman...E-SHIPPING_p_36.html
LS4FieroGuy
Report this Post11-30-2024 11:06 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
[URL=https://halferlandperformance-
com.3dcartstores.com/EGRBlock-Off-Plate--HLP-Products-V2-Billet-CnC-EGR-Block-off-Plate-FITS-AL
L-HONDA-CODES-BCDKHFJ-FREE-
SHIPPING_p_36.html]https://halferlandperforman...E-SHIPPING_p_36.html[/URL]
What about routing it to fresh air? Instead of blocking it off.
Total ratings: 200
Report this Post11-30-2024 11:42 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
No, that's not something you want. The EGR displaces fresh air already in the intake with exhaust from the two middle exhaust ports, it can't be modified to add MORE fresh air.. otherwise you'd just have a massive vacuum leak.
jelly2m8
Total ratings: 242
Report this Post12-01-2024 01:42 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
You Won't gain nothing at all, what you will do is increase cylinder temperatures which will effect ARF ratio's and will effect fuel tables, so most likely in a stock engine, an overall loss.
jelly2m8
Total ratings: 242
Report this Post12-01-2024 01:44 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
jelly2m8
Member since Jul 2001
The purpose of the EGR is to reduce NOX gasses, a good byproduct of that is it lowers the combustion chamber temperature.
