  blower fan switch power
blower fan switch power by Vernonmera
Started on: 01-23-2025 03:48 PM
Replies: 3 (90 views)
Last post by: Vintage-Nut on 01-25-2025 10:30 AM
Vernonmera
Report this Post01-23-2025 03:48 PM Click Here to See the Profile for VernonmeraSend a Private Message to VernonmeraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi All, I have run into a problem I wanted to run by you all....I have a heater blower fan that won't run (1987 mera)...I have checked fuse, blower motor, relays...and today I finally worked back to the blower fan switch only to discover no power there at all. The ground 201 seems fine....so I am guessing I have a bad wire from the fuse block to the switch itself. I just wanted to check to see if anyone had any other ideas before I start looking to run a new wire. thanks
Vintage-Nut
Report this Post01-23-2025 05:02 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
If HTR A/C Fuse has 12V on the Brown Wire
But not at the Blower Switch tab 'E'
You have an open Brown wire from the fuse block to the switch....
Vernonmera
Report this Post01-25-2025 08:56 AM Click Here to See the Profile for VernonmeraSend a Private Message to VernonmeraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks - I will try to check that later today...will let you know what I discover
Vintage-Nut
Report this Post01-25-2025 10:30 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI
HTR A/C Fuse feeds three brown wires:
*Heat Blower Switch
*A/C Power Relay
*A/C Control Head
The Heat Blower Switch schematic shows one brown wire without any breaks from the fuse block to the switch
