  Washer nozzle shims
Washer nozzle shims by MRBLUE87
Started on: 01-26-2025 05:12 PM
Replies: 2 (70 views)
Last post by: Mike in Sydney on 01-27-2025 09:22 PM
MRBLUE87
Report this Post01-26-2025 05:12 PM Click Here to See the Profile for MRBLUE87Send a Private Message to MRBLUE87Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anybody have any of the wedged shims for aiming the windshield washer nozzles? Or the GM part number?
Vintage-Nut
Report this Post01-26-2025 05:33 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
See "WTB - Windscreen Washer Nozzles " in 'TheMall' as a member had the nozzles...
https://www.fiero.nl/forum/Forum4/HTML/080858.html
Mike in Sydney
Report this Post01-27-2025 09:22 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Purchase some acetate film or folders from an office supply store. Cut it into 1/4" wide strips and put it under the nozzle. Put it at the front of the nozzle (Close to the windshield) to move the spray pattern up. Put the strips at the back to move the spray pattern down.
I've found that it doesn't take a lot to move the pattern up or down but to fine tune it you may need to put multiple strips under the nozzle. Be very careful in removing the hose from the nozzle. The nylon / plastic fixture is at least 36 years old so on my car , it has become brittle. (I would suggest that you move 3-4 inches away from the nozzle and cut the hose. Use a barbed connector to connect the hose when reinstalling the nozzle.)
