  Rear bumper gap / how to fix it??
Rear bumper gap / how to fix it?? by Kitskaboodle
Started on: 03-10-2025 09:12 PM
Replies: 11 (206 views)
Last post by: Kitskaboodle on 03-21-2025 02:32 PM
Kitskaboodle
Report this Post03-10-2025 09:12 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I’m certain this a common Fiero issue.
Both of my Fiero’s have a quite pronounced gap between the bottom of the tail lights and the black plastic moulding above the rear bumper.
How exactly do you close the gap? Do I need to remove the tail lights? The whole rear bumper?
If you have fixed your gap, tell me how you did it? I’m hoping it’s not a major project.
Oh, and pics are much appreciated. 😊
Thanks, Kit
[This message has been edited by Kitskaboodle (edited 03-10-2025).]
Vintage-Nut
Report this Post03-10-2025 09:17 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Kit,
Why not post 'your' gap....?
Total ratings: 206
Report this Post03-10-2025 09:24 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull the taillights and loosen the top (push pins) and sides of the bumper cover (side marker lights, wheel house liner)
There is a metal shelf below the taillight area.
Bend the metal shelf up to restore the desired gap.
Reassemble.
It should take an hour or two to accomplish.
Total ratings: 465
Report this Post03-10-2025 10:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
My '84 and '86 are metal, I believe my '87 is metal as well. The design was changed for '88, as my Formula has a plastic shelf.
If I remember correctly, there's some adjustment available with the position/height of the shelf. But yeah, the metal ones could've sagged downwards and might need to be bent back up.
The shelf can be seen below.
Originally posted by Quadfather:
[This message has been edited by Patrick (edited 03-10-2025).]
Kitskaboodle
Report this Post03-10-2025 10:50 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, here are two pics from different angles. Sorry, it’s late at night and these pics will have to do.
Thanks guys for the info. My liners are already out so it shouldn’t be too bad at this point.
As an fyi, this is my 85 GT we’re talking about.
Best regards, Kit
Total ratings: 206
Report this Post03-11-2025 07:55 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
My Formula, my son's 88 base coupe and a Formula spaceframe that we have here all have metal shelves.
I wonder if yours is missing or if it was a Canadian model thing.
I have seen different gage metal used in different model years and the base model and 86 and up GT's are different as well.
Another Fiero puzzle....
Vintage-Nut
Report this Post03-11-2025 09:12 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
olejoedad:
My '88 GT has a metal shelve too.....
Your photos shows that the lower 'bumper' {fascia} isn't meeting the upper fascia.
olejoedad said, remove the taillights, side marker lights and the wheel well liners
Loosen the sides of the bumper/fascia cover
Bend the metal support upward to restore the desired gap
EDIT for a thought: Maybe I'm wrong but I believe that the lower fascia screws are fasten on the upper fascia with metal clips which are threaded, meaning no 'nuts'. Perhaps you don't have to remove the wheel well liners....?
[This message has been edited by Vintage-Nut (edited 03-11-2025).]
Kitskaboodle
Report this Post03-20-2025 08:36 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi gang…… 😊
First, to answer the question above: you’re probably right that you don’t need to remove the wheel well liner from the car but you really need to remove at least the rear lower screws that secure the liner to the bottom section area of the rear bumper fascia.
Ok, so I got it done. First order of business is to remove the tail lights, then the side marker lights and extra screw, then all the plastic push pin fasteners, then I marked the bottom edge of the metal shelf with a silver marker, then I removed all seven 10mm screws that attach the shelf onto the rear sheet metal. Then I elongated the holes in the shelf mounting bracket so that I would have additional room to move the shelf upward.
Observation#1 The main culprit for the sagging “gap” is that over time the shelf works it’s way downward to the point where the screws are resting at the top of the hole. (if you look closely at YOUR shelf, you will see that those seven holes are over size on purpose to allow for adjustment.
Observation#2 No offense to those who recommended bending the shelf upwards to close the gap and fix the problem, I didn’t like the idea of bending & tweaking that shelf. I felt that the “proper” way was to elongate the holes. Yes, my way was more work but I felt it was a better, more quality approach to the problem.
Ok, here are a few pics:
And thanks to all for your help on this!
Kit
P.S. First pic below shows how much I elongated the shelf holes.
2nd pic shows the shelf before I removed it.
[This message has been edited by Kitskaboodle (edited 03-20-2025).]
Kitskaboodle
Report this Post03-20-2025 08:55 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kitskaboodle
Member since Nov 2004
More pics…
Lower pic shows just how much I moved the shelf upward. (see silver lines that I marked before removing shelf) Also, notice that I used oversized washers to secure the shelf better.
Top pic shows everything all back together.
Total ratings: 465
Report this Post03-21-2025 04:14 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't swear to it, as this was years ago... but I also stripped down an '88 base coupe before it was scrapped, and I seem to recall it had the same plastic shelf as my Formula. Come to think of it, that plastic shelf is probably somewhere in my basement. I would have wanted to save it as the plastic shelves are much more skookum than the stamped out sheet metal ones. It's difficult to believe though that something like this would be a "Canadian model thing".
[EDIT] It just dawned on me that my Formula was originally from Knoxville, Tennessee... so that would seem to put the "Canadian" theory to rest.
[This message has been edited by Patrick (edited 03-21-2025).]
Vintage-Nut
Report this Post03-21-2025 07:37 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congratulations Kit - Good Job!
Kitskaboodle
Report this Post03-21-2025 02:32 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
And thanks again for all the advice & tips. 😊
Kit
