  Synthetic blend 5w-30 in getrag
Synthetic blend 5w-30 in getrag by gregr75
Started on: 03-15-2025 12:34 PM
Replies: 8 (164 views)
Last post by: Vintage-Nut on 03-16-2025 01:39 PM
gregr75
Report this Post03-15-2025 12:34 PM Click Here to See the Profile for gregr75Send a Private Message to gregr75Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used valvoliine synthetic blend 5w-30 to change my engine oil. After draining my transmission, Can i use the same for my 5 speed getrag?
the old manuals back in the day called out 5w-30 for the getrag. But that was probably for conventional oil. Just wondering if synthetic blend makes a difference better or worse.
87 GT Stock 2.8L
Total ratings: 206
Report this Post03-15-2025 12:56 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ran mobil one in my 4 speed for years and it shifted smoother as soon as I put it in.
It won't hurt a thing.
Total ratings: 465
Report this Post03-15-2025 03:38 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not saying that what you wish to try is bad by any means... but you do realize that Synchromesh has been recommended by GM for a long time, right?
Vintage-Nut
Report this Post03-15-2025 06:17 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
'88 Getrag syncromesh fluid
https://www.fiero.nl/forum/Forum2/HTML/148106.html
[This message has been edited by Vintage-Nut (edited 03-15-2025).]
cvxjet
Report this Post03-15-2025 09:06 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was using motor oil as per owner's manual.....then someone recommended the GM Synchromesh fluid- big improvement in shifting!
To give you an idea how good this fluid is, All of the Honda/Toyota/Subaru guys have switched to using it....
It is available from different manufacturers- Penzoil/Valvoline/Amsoil as well as AC/Delco who invented it.
cartercarbaficionado
Report this Post03-15-2025 09:49 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
also mustang guys with the garbage 2013 6 speeds lol.
also word if warning this will cause rubber hoses to leak in certain honda models (the early 90s manual accords used the diff as a fluid pump into the steering rack to stiffen it at speed. they leak if you dont use 5-30 with a additive so just replace those lines)
Vintage-Nut
Report this Post03-15-2025 10:06 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not True - Synchromesh fluid will not cause rubber hoses to leak.
Yes, the fluid is thin, and some has blamed the fluid when their seals started leaking, but the 'real' problem is old rubber....
gregr75
Report this Post03-16-2025 12:43 PM Click Here to See the Profile for gregr75Send a Private Message to gregr75Edit/Delete MessageReply w/QuoteDirect Link to This Post
I know synchromesh is better, but I have a small oozing external leak from my transmission… And because the stuff is lower viscosity, I'm afraid that leak may get worse.
not sure I want to try it until I get the transmission leak fixed.
Vintage-Nut
Report this Post03-16-2025 01:39 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
The original GM spec was engine oil, some use 5w-30
Synchromesh is better for smoother shifting
Heavier oils can be a shifting issue during cold starts/weather...
BTW - the molecules in synthetic oils are smaller than conventional oils
SO, going back to your question:
You can, but if you're worried about synchromesh, then I believe you will be worried about Valvoline synthetic blend 5w-30 too...
Read more on PFF
https://www.fierosearch.com...trag&Action=DoSearch
[This message has been edited by Vintage-Nut (edited 03-16-2025).]
