Best Brake calipers to get off Rock Auto? by the_snowman
Started on : 03-15-2025 01:18 PM
Replies : 19 (199 views)
Last post by : the_snowman on 03-15-2025 04:22 PM
Mar 15th, 2025
the_snowman Member Posts: 25 From: AB Registered: Mar 2025
As i am still very new to fieros, this forum has been such a big help!
So i am wondering if anyone has bought new rear and or front brake calipers from rock auto?
If so, then what are your recomendations?
This is for an 88 GT 2.8L
Also are there any differnces in the 87 GT breake calipers than the 88?
[This message has been edited by the_snowman (edited 03-15-2025).]
01:18 PM
olejoedad Member Posts: 19625 From: Clarendon Twp., MI Registered: May 2004
84-87 use the same calipers. The rotors are not vented 88 calipers were only used on the 88 Fiero, no other GM car used them. The rotors are vented, therefore they are thicker that the pre-88's. 88 calipers are very hard to come by. Are your 88 calipers not working?
01:34 PM
ohhh, okay. yes, my calipers on all four are not working. with some work they can be fixed, but i have a time limit on how long i can work on my fiero. it is currently at a friends garage, and he would like it out asap.
01:43 PM
fieroguru Member Posts: 12425 From: Champaign, IL Registered: Aug 2003
quote Originally posted by olejoedad: 84-87 use the same calipers. The rotors are not vented 88 calipers were only used on the 88 Fiero, no other GM car used them. The rotors are vented, therefore they are thicker that the pre-88's.
The 88s also have a different caliper bolt pattern, as well as offset side to side and radially.
02:11 PM
quote Originally posted by the_snowman: yes, my calipers on all four are not working.
All the rockauto 88 fiero calipers are out of stock.
Calipersonline has the front ones. If you don't want/need a parking brake, you can use the 88 front calipers in the rear.
http://www.calipersonline.com/pontiacfiero.aspx
02:17 PM
I've run front calipers on all four corners on my 88 Formula for quite some time with no issues.
02:57 PM
Vintage-Nut Member Posts: 1382 From: California Registered: Apr 2020
Most members want a working parking brake...
quote with some work they can be fixed, but i have a time limit on how long i can work on my fiero. it is currently at a friends garage, and he would like it out asap.
IF you have good '88 cores; see this thread:
1988 rear brake options by Dave Deerson
https://www.fiero.nl/forum/Forum2/HTML/148372.html ------------------
[This message has been edited by Vintage-Nut (edited 03-15-2025).]
02:57 PM
So if i would like to keep the parking-brake, then i would need to rebuild them?
03:07 PM
The rear piston actuator / parking mechanism is the 'key'...
Some remanufacturing business fails from the box and members reported lots of horror stories about getting crappy rebuilds.
Do you have ANY fluid coming out of the center hole of the rear piston?
03:17 PM
No fluid from the piston at all.
03:21 PM
quote my calipers on all four are not working.
Say more; 'why' they're not 'working'?
Did you bleed the lines, and you have a 'problem'?
03:25 PM
What i know so far is that the wheels can move semi freely, When the brake petel is depressed the brakes do not apply more or less after it is relesed. The calipers have surface rust ( from what i have seen so far ) witch do not let them relese form the rotor. When i blead the breaks and manualy tried to move the brake pads to put more force on the rotor and vise versa the pisoton would only push the brake pads onto the rotor, and not pull back when it should. that is so far what i know.
03:31 PM
I bet your sliders are 'dry'...
IF the piston WILL move WITHOUT pads; grease the sliders.
Do you have the 1988 Pontiac Fiero Service Manual?
https://fieroinfo.com/manua...o_Service_Manual.pdf [This message has been edited by Vintage-Nut (edited 03-15-2025).]
03:37 PM
The piston still moves, but it only moves forward whn i manualy do it with my hands.
Not with the brake pedel, so i am a bit confused.
do you think it is worth my time to take the caliper apert and rebuild it?
or it there an easy fix to this problem, if it is the caliper at all?
9 I do have servus manuels for the 88 and 87
03:43 PM
Did you bleed the lines - Yes or No Do you have pressure to clamp the pads to the rotors - Yes or No
03:55 PM
I did bleed the lines - Yes
I did not have pressure when i did it with the pedel - No
i did when i too the break lines off and the spring off and manuely tried top see if it did - Yes
03:57 PM
quote I did not have pressure when i did it with the pedel - No
Remove the master cylinder, bleed the master cylinder
on the bench to verify IF the master cylinder will push fluid from both ports....
IF NO; get a new master cylinder and bleed it on the bench BEFORE installing it.
See "bleed a brake master cylinder on the bench" on the internet
04:08 PM
Will do, Thank you for your help!! also thank you for putting up with my lack of knowlage!!
04:10 PM
You're welcome...
When you have a working master cylinder on the bench and ALL the air purged, install it WITHOUT getting any air inside....
Before installing the working master cylinder ; clean the calipers and
grease the sliders Also read in the manual 'how' to rotate the pistons into the calipers before installing the pads
04:21 PM
Will Do.
04:22 PM
