  Duke rebuilding
Duke rebuilding by LS4FieroGuy
Started on: 03-15-2025 10:41 PM
Replies: 16 (190 views)
Last post by: mountainman on 03-19-2025 10:15 PM
LS4FieroGuy
Report this Post03-15-2025 10:41 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I'm rebuilding an 88 Duke and I can't find where the oil pump mounts. Also did some of the 88 Dukes not have an oil drain plug?
Joshua Seeger
cartercarbaficionado
Report this Post03-16-2025 12:59 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
some pictures might help. they all had drain plugs but i believe they are the filter cover piece itself on the 88s
as for the pump? no idea without a picture of what your looking at
[This message has been edited by cartercarbaficionado (edited 03-16-2025).]
Report this Post03-16-2025 01:19 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Sep 2023
https://www.ebay.com/itm/296872765642
https://www.ebay.com/itm/142386410380
thst should fix your problem if you have the wrong one. i just so happened to have a gm oem dealers manual for a celebrity with a R vin engine
other part numbers you might need are
10038405
12508076
LS4FieroGuy
Report this Post03-16-2025 10:44 AM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what is this?
LS4FieroGuy
LS4FieroGuy
Member since Mar 2024
Report this Post03-16-2025 06:26 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
So what is this?
thats the oil pump for a 87-88 only iron duke.
LS4FieroGuy
Report this Post03-17-2025 12:12 AM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just tore an 88 Duke apart and that wasn't in there.
Report this Post03-17-2025 02:17 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
that balance shaft assembly has the oil pump and is SUPPOSED to be there. i litterally called and asked the entire jet city fiero club to make sure that 88 used that part. (edit wrong about 87. got dates wrong because of the year crossover)
if you still dont believe me heres a thread about this.
https://www.fiero.nl/forum/...110502-2-107077.html
[This message has been edited by cartercarbaficionado (edited 03-17-2025).]
Report this Post03-17-2025 02:18 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
also like maybe show a picture of the bottom of the engine where your trying to mount the pump to.
Report this Post03-17-2025 06:29 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I concur with CarterCarbs here... that device / component has the balance shafts and the oil pump built in as one unit. The 88 Duke is a pretty cool motor with the enhancements they made... but that oil pump you're showing (the Melling), I'm almost positive that's for 84-86 (87?) Iron Dukes. It's identical to the one my daughter installed in her Iron Duke. I don't think you'll be able to use that one.
LS4FieroGuy
Report this Post03-17-2025 08:27 AM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok. I guess a good follow up question is do they sell a high flow pump for the 88?
Report this Post03-17-2025 05:34 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
no. it doesnt need one. its litterally the 2 psrts i linked and im wondering what you are looking at on the engine currently.
LS4FieroGuy
Report this Post03-17-2025 11:25 PM Click Here to See the Profile for LS4FieroGuySend a Private Message to LS4FieroGuyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah so I was just wondering if there was any sort of high flow version of the two pieces that you linked.
Report this Post03-18-2025 01:25 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
no. not anymore at least...
i would like you to actually upload a picture of your block and chunks of aluminum you found regardless
Report this Post03-18-2025 07:08 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just tried searching, but all that came back were the oil pumps from the earlier years.
The Iron Duke... in the form that you have it, was really only in GM cars from 1988-1992. The problem is that outside of cars like the Fiero, or some one-off other GM cars, most of the vehicles with the Iron Duke in them were not highly valued cars... so the availability of 1988+ Iron Duke parts is slim to none. They also used this engine in the mail truck from 1987 through 1994... and for almost the entire life of the vehicle (which they called the LLV / Long Life Vehicle) by Grumman, they had your version in it. But all of those vehicles get returned back to Grumman at the end of their life-span, and crushed, with the engines recycled.
So, parts for the 88-specifically are really hard to find. I know that doesn't help... but I would keep an eye out for 88+ engines on eBay. They do pop up from time to time. You can also reach out to all the Fiero used parts suppliers, which should be able to get you some of the things you need. For everything else... you can buy all the rebuild parts on Rock Auto.
But this throws me for a loop...
You're saying that the device quoted above, wasn't found in your 88 engine that you've opened up? As in, under the oil pan? That round screen in the picture is the pick-up for the oil on the 88+ Duke.
Can you post pictures of your engine? I'm wondering if someone swapped in a different motor.
Can you check the year on your block? It should be embossed somewhere on the exhaust side of the engine.
richard in nc
Report this Post03-18-2025 05:55 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
only the 1988 fiero had the filter in the oil pan.
mountainman
Report this Post03-19-2025 10:15 PM Click Here to See the Profile for mountainmanSend a Private Message to mountainmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, the 87 block uses a regular oil pump. And a standard type of oil filter. It does have the DIS igintion system. 88 has the force balancer with built in oil pump and oil filter. To replace the oil filter you remove a four inch drain plug from the bottom of the oil pan, then pull the filter out of the same drain hole. jm
