  Where to buy 3.4 swap fuel injectors
Where to buy 3.4 swap fuel injectors by Filben
Started on: 03-16-2025 11:42 AM
Replies: 2 (66 views)
Last post by: Filben on 03-16-2025 03:20 PM
Filben
Report this Post03-16-2025 11:42 AM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am doing a 3.4 swap and the injectors from the donor engine have a crack in one of them. I want to replace them but want to know where to buy a reputable set. Ebay has chinesium for $50 for a set, I'm sure those will work great said no one ever. Who do you trust for a good set?
Total ratings: 154
Report this Post03-16-2025 02:38 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
After trying several different injectors, this is what I ended up with that worked satisfactorily in my 3.4 swap. From Motor Man Fuel Injectors. Also check with CS Performance Injectors. I have successfully been running these injectors in my 3.4 since 2018, first on the stock 87 ECM and now on the 7730 ECM conversion.
https://www.motormanfuelinj...ctor-0280150415.html
Bosch EV1 Fuel Injector
Jetronic port / 4 hole nozzle
Flow rates @ 43.5 psi / 3 bar
16.76 lb per hour (My Note: 17# rated injectors flow at approximately 16.666 lb/hr at 3 bar or 43.5 psi. See calculator chart below)
126.5 G per min. (N-Heptane)
176.1 cc per min
15.90 Ohm resistance
Note these numbers. Though the same Bosch part number I originally listed, the BMW part number has changed. This injector is for the BMW M3.
Bosch Part # 0280150415
BMW part # 13641730060
CHART FROM MOTOR MAN FUEL INJECTOR SUPPLY
Fuel Injector Size Calculator
Horsepower (at the flywheel) 160
Number of Injectors 6
B.S.F.C. *
Max Duty Cycle in % 80
Required Injector Static Flow Rate @ 43.5 psi lb/hr 16.666
cc/min
[This message has been edited by fierofool (edited 03-16-2025).]
Filben
Report this Post03-16-2025 03:20 PM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
176.1 cc per min
B.S.F.C. *
cc/min
Nice, bought a set. Tired of buying parts, want to keep putting parts on to hopefully drive this pile someday.
