  2.8 in an 2.5 Fiero
2.8 in an 2.5 Fiero by 279fiero84
Started on: 03-16-2025 12:56 PM
Replies: 3 (89 views)
Last post by: MulletproofMonk on 03-18-2025 03:37 PM
279fiero84
Report this Post03-16-2025 12:56 PM Click Here to See the Profile for 279fiero84Send a Private Message to 279fiero84Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for allowing me to join!
I have a question about putting a 2.8 MPI from a 88 Celebrity in place of my 2.5. Has anyone done this with the later 2.8L MPI? Also will the transmission bolt up or do i have to swap the whole drivetrain in? Thank you
55 Chevy, 87 Monte Carlo SS, 84 Z28, 84 Fiero
cartercarbaficionado
Report this Post03-16-2025 06:29 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
it will bolt in mostly. the 84 harness needs some modifications though
MulletproofMonk
Total ratings: 78
Report this Post03-18-2025 03:17 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Celebrity 2.8L is rated at 125 hp and the Fiero 2.8L is rated at 140 hp
If you are pulling the motor from a junkyard, you might ask around if someone is selling a Fiero 2.8L or even someone pulling out a 3.4L (165 hp)
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
MulletproofMonk
Total ratings: 78
Report this Post03-18-2025 03:37 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
MulletproofMonk
Member since Oct 2005
So you are basically moving the motor from the front of the car straight back into the Fiero engine compartment.
Your intake will be pointed to the left side, but you are going to have to deal with
intake hose
exhaust manifolds to the exhaust since you have a 4cyl
wiring harness
oil fill will be against the firewall
mounts will probably be different
fuel lines probably aren't going to line up
-Brian
