  Throttle blade angle on 2.8 throttle body
Throttle blade angle on 2.8 throttle body by 1985 Fiero GT
Started on: 03-16-2025 01:17 PM
Replies: 3 (71 views)
Last post by: pmbrunelle on 03-17-2025 05:23 PM
1985 Fiero GT
Report this Post03-16-2025 01:17 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, I noticed on my throttle body that full throttle doesn't put the throttle blade at an exact 90*, keeps it slightly angled, is there a reason for this? There is a stop that protrudes and stops it at wide open throttle before 90*, just curious why. I would assume a perfect 90* would be the best for airflow.
Total ratings: 465
Report this Post03-16-2025 03:59 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You'd be wrong then.
If you google it, you'll discover it has to do with turbulence. An example of these many online discussions is Here.
1985 Fiero GT
Report this Post03-16-2025 04:17 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting, that makes sense
pmbrunelle
Total ratings: 63
Report this Post03-17-2025 05:23 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
From some online searches I did (since I saw this topic), in some cars where the throttle body is part of a curvy path, having the throttle plate angled may help guide the air where it needs to go.
I don't know if we can determine the optimum throttle angle for the Fiero V6 without flow testing.
From this article:
https://www.mdpi.com/2227-9717/11/7/1897
This graph shows how the flow of a throttle changes with throttle angle:
There is not much gain from 80° to 90°.
A throttle like this could feel non-linear to the driver, where the last 10° of travel doesn't change the engine output very much (as in, a dead spot). So, with a cable throttle, you may wish to limit the travel to have a more linear-feeling throttle.
Of course, with drive-by-wire, you can hide this behaviour from the driver, as throttle plate position is independent of accelerator pedal position.
On the White Bug, I took a guess and I grinded the throttle stop so that the throttle plate could rotate to 90°.
From the seat of the pants the engine feels okay I guess
Of course, the engine is turbo, so throttle linearity went out the window anyway...
I don't have a very strong opinion on the topic.
