  Potential low power
Potential low power by Josh86gt
Started on: 03-16-2025 09:03 PM
Replies: 14 (214 views)
Last post by: Josh86gt on 03-25-2025 09:02 AM
Josh86gt
Report this Post03-16-2025 09:03 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was taking my fiero for a spin earlier today and the battery meter was only reading 13 volts which I thought was weird it seems a tad low and when it got darker I went to turn on my headlights and they only went up about halfway I had to hold the switch half on half off for them to go up fully would this be a weak alternator?
Total ratings: 465
Report this Post03-16-2025 09:43 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Josh86gt:
...would this be a weak alternator?
Probably. Should be showing a charge of more like 14.6v
Josh86gt
Report this Post03-16-2025 09:46 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay thanks it's been worrying me for a while some of the lights on my dash also flicker but that could just be a loose connection
Total ratings: 465
Report this Post03-16-2025 10:02 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before changing the alternator... make sure the connections (on battery, power junction, and ground) are corrosion-free and tight. Use a standalone volt/multimeter to measure what the alternator is putting out.
[This message has been edited by Patrick (edited 03-16-2025).]
Vintage-Nut
Report this Post03-17-2025 09:01 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start with a fully charged battery as the Generator/Alternator will not even try to charge an undercharged battery...
Use a voltmeter to measure the battery - 12.5 DC Volts or Better
*If the battery won't hold 12.5V after charging - replace it
Check the Generator/Alternator Belt Tension
With a fully charged battery...
Use a voltmeter to measure the battery at idle AND 3k RPM - 13.5 volts to 14.5 volts
*If the Generator/Alternator won't charge the battery at 13.5 volts to 14.5 volts...then
Check the Generator/Alternator Connections
With the KEY at RUN position {Engine NOT Running}
Check All Cable/Wires Have 12V
*If NO, check the fuses/wires/cable
*If ALL have 12V - replace the Generator/Alternator
[This message has been edited by Vintage-Nut (edited 03-17-2025).]
Josh86gt
Report this Post03-17-2025 07:01 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay so I finally got around to testing my alternator and it worked just fine but my headlights still seem to not go up when I flip the switch all the way I have to hold it halfway and some of the lights on my dash tend to flicker when I turn them on would that be a bad headlight switch?
Vintage-Nut
Report this Post03-17-2025 07:13 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Start there, you can try cleaning it or:
The Fiero Store Headlight Switch / Part # 51426
https://www.fierostore.com/.../Detail.aspx?s=51426
AC Delco
https://www.partsgeek.com/v...eadlight-switch.html
Wells
https://www.partsgeek.com/f...eadlight-switch.html
Standard Motor Products
https://www.partsgeek.com/4...eadlight-switch.html
Edit for a Warning
The headlight switch is HOT at All Times!
Disconnect the battery before removing the switch
[This message has been edited by Vintage-Nut (edited 03-18-2025).]
Josh86gt
Report this Post03-18-2025 06:25 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay so I finally got around to taking out the light switch does anyone know how to disassemble it without breaking it?
Vintage-Nut
Report this Post03-18-2025 09:17 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it is sealed - 'flood' the unit with electrical contact cleaner as flipping the switches
Fully Dry It, and Test It...
Josh86gt
Report this Post03-18-2025 09:18 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok thanks
cartercarbaficionado
Report this Post03-18-2025 11:47 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
i usually just grab the ones from a firebird or camaro imma be real. i think theres some plastic tabs somewhere
richard in nc
Report this Post03-19-2025 06:46 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
a new switch is surprisingly cheap.
1985 Fiero GT
Report this Post03-19-2025 09:06 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
$20 on rock auto
Vintage-Nut
Report this Post03-25-2025 08:35 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Apparently, this is another thread which the OP didn't respond as it is 'solved' or not...
Josh86gt
Report this Post03-25-2025 09:02 AM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have not solved it yet I replaced the switch and it is still broken and I'm just going to leave it alone for now
