  Rayne/Weld/Arraut/WestShore front coil-over replacement shocks?
Rayne/Weld/Arraut/WestShore front coil-over replacement shocks? by lou_dias
Started on: 03-19-2025 01:24 PM
Replies: 4 (93 views)
Last post by: lou_dias on 03-19-2025 09:30 PM
lou_dias
Total ratings: 67
Report this Post03-19-2025 01:24 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone have a replacement front shock part #?
Summit doesn't seem to let me filter by body diameter or recommended spring inside diameter...
I need like a 1.625" or so body diameter adjustable-height shock.
My front shocks are completely shot. New 8" tall 1.875" ID springs I already have. The old springs were reduced to 6"...they were shot too.. :/
Vintage-Nut
Report this Post03-19-2025 02:21 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you look at West Coast's set?
https://westcoastfiero.com/...e-performance-shock/
Larryinkc
Report this Post03-19-2025 04:09 PM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Arraut front coilover conversion on my 88.
The shocks that it came with are QA1 DS402 with SS110SDM stud top conversion kit.
Hope this helps.
lou_dias
Total ratings: 67
Report this Post03-19-2025 04:26 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Edit: HELD ...not WELD...
Mines is the Slalom kit for the 87 so I don't believe those will work for me. :/
They have a 2" body with a 2.5" ID recommended spring. My spring ID is 1 7/8" ...
On a brighter note they sell this kit to give me a top eyelet which is what I need...so now I can expand the range of shocks to look for...
Thanks for the kit #!
https://qa1.net/products/qa...kit-ss300lt-ss300lt/
Extra edit:
WestCoast doesn't list specs... However, I'll look into Viking shocks.
[This message has been edited by lou_dias (edited 03-19-2025).]
lou_dias
Total ratings: 67
Report this Post03-19-2025 09:30 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
lou_dias
Member since Jun 2000
Ok, I downloaded the entire QA1 catalog and found what I need.
8Q53 is 1 5/8" (8Q51 and 8Q52 were also options)
CK8Q00 is the kit to hold the 1 7/8" ID spring
