  Aftermarket Front Brake Identification?
Aftermarket Front Brake Identification? by Kitopher
Started on: 03-20-2025 08:31 PM
Replies: 5 (107 views)
Last post by: richard in nc on 03-21-2025 06:07 PM
Kitopher
Report this Post03-20-2025 08:31 PM Click Here to See the Profile for KitopherSend a Private Message to KitopherEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am attempting to replace my rotors and pads on all 4 corners.
The rotors are obviously not original, as they are drilled, and noticeably thicker than stock.
My concern stems from the caliper, which also appears to not be stock, probably to accommodate the larger rotor.
I bought the car with these brakes on, and the owner before me said they were like that from the owner before him.
I would love some help identifying these rotors/calipers so that I can replace the pads and anything else accordingly with parts that fit.
The caliper does have some stamped numbers, WN4, 339, 931, 127, 932, 2?5,108.
I have no idea what these mean.
These are the pads that came off it, they are noticeably different than the stock ones sold at autozone or the fierostore.
This is the rotor, it has no visible markings of any kind.
Kit G
cartercarbaficionado
Report this Post03-20-2025 08:39 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
do me a favor and measure the brake rotor diameter. it'll help alot to identify what caliper you may have
Report this Post03-20-2025 08:43 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Sep 2023
i THINK those are beretta calipers actually. see if the pads reccomended for that swap fit
edit:i am wrong, that is a 88 grand am caliper here are your pads
https://www.autozone.com/br...set-mkd289/90029_0_0
[This message has been edited by cartercarbaficionado (edited 03-20-2025).]
Kitopher
Report this Post03-20-2025 09:33 PM Click Here to See the Profile for KitopherSend a Private Message to KitopherEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would the rotors also be from a grand am then?
I need new bearings n whatnot so gotta make sure I get the right one of those too.
Also thank you so much, that was impressively fast!
Report this Post03-21-2025 06:34 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
probably? see what other people do for a grand am swap as im not too familiar with it
richard in nc
Report this Post03-21-2025 06:07 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
the grand am swap uses a stock modified fiero hub.the hub should be seperate from the rotor.
