A CV joint boot rips when the back wheels spin under power when they lift off the ground. Best fix is to replace with a new boot. The handicap for using the split boot as a repair is that they use adhesive to keep the boot together. The CV boost location is loaded with grease and if even a small amount gets on the new boot new seam it will completely fail.
"THE COLUSSUS" 87GT - ALL OUT 3.4L Turbocharged engine, Garrett Hybrid Turbo, MSD ign., modified TH125H
" ON THE LOOSE WITHOUT THE JUICE " [This message has been edited by Dennis LaGrua (edited 03-26-2025).]
