  Dancing speedometer
Dancing speedometer by fierobear
Started on: 03-24-2025 12:22 PM
Replies: 7 (104 views)
Last post by: fierobear on 03-26-2025 09:07 AM
fierobear
Total ratings: 383
Report this Post03-24-2025 12:22 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, hell. The black Formula had been running great with few glitches. Then suddenly, the speedometer started dancing around while driving. I put a different 120mph speedo in there, and it did the same thing. Seems steady until about 40mph, then it gets worse the faster I go. No code 24, so something past the point of the VSS or ECM. Any ideas where to start checking the wiring?
Total ratings: 206
Report this Post03-24-2025 12:40 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The VSS signal wiring starts with the VSS plug and goes to C203 G, C203 R. The signal then goes to the speedo module in the speedo that is grounded thru C203 M, and the 2000ppm signal to the ECU goes to C203 H.
C203 H communicates with the ECU at connector 2, plug A10.
Check the grounding of C203 M and all of the various connectors.
Also check the integrity of the wiring terminals at the VSS plug.
fierobear
Total ratings: 383
Report this Post03-24-2025 12:46 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds good, I'll start checking. Thanks.
Total ratings: 206
Report this Post03-24-2025 01:54 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let me know what you find.
fierobear
Total ratings: 383
Report this Post03-24-2025 09:35 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't have a chance to look at any other wiring yet, but started at the VSS. The wiring looks pretty...crappy.
Here is the wiring at the VSS, unplugged to show how ragged the wires are:
Total ratings: 206
Report this Post03-24-2025 10:28 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like a good place to start!
Vintage-Nut
Report this Post03-25-2025 07:48 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW - speedometer board often been found as the problem.....
Troubleshooting the Fiero Speedometer System by Oliver Scholz
http://www.fieros.de/en/articles/speedo.html
fierobear
Total ratings: 383
Report this Post03-26-2025 09:07 AM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Based on reading the above, a failure on the board(s - the replacement did the same thing) could be the issue. I'll test everything. Thanks!
