  2.8 v6 clutch reccomendations
2.8 v6 clutch reccomendations by cartercarbaficionado
Started on: 04-01-2025 10:48 AM
Replies: 5 (106 views)
Last post by: hnthomps on 04-17-2025 03:08 PM
Report this Post04-01-2025 10:48 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
the Tangerine menace decided to start having a slipping clutch so im not sure what to put in it currently.. the 3.4 swap is put off semi indefinitely until i find one that isn't 3k or needs everything...still looking for an lq1
anyways it had a stage 2? i think is what the previous owner had said and ive heard mixed things about the ram clutches. it is a stock 88 formula now (minus the ocelot exhaust and higher flow intake box and filter) but we have alot of hills and it tends to be a little low on torque down low sometimes (idk what it is i stopped being there to fix it)
hence looking for something that can take a little more slipping especially for the awful gridlock traffic
marc-alan
Report this Post04-02-2025 01:07 AM Click Here to See the Profile for marc-alanSend a Private Message to marc-alanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Previously I used a luk clutch on a 3.4 push rod motor and felt it was ok this car was sold a few years ago. For the current build in a different car I upped it to a spec stage 2, this is a 3.4 with a cam, dohc pistons, some porting, roller rockers, so far happy with choice.
The reason I moved from the luk clutch is that we have one in a lq1 motor and found it to be slipping when launching the car. We have spec 2 clutch now for that car and will change it out later.
Total ratings: 461
Report this Post04-06-2025 10:46 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the HD Ram clutch bolted to my 4.9. It does fine, although there is a ton of torque down low, since it's a tractor motor.
Report this Post04-06-2025 11:23 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
ive heard the 4.9 can shred those pretty easy and they tend to throw the springs out. not sure how true it is but ive had luk reccomended to me 20 times now so it'll likely be a luk i go with if not the larger diameter ram clutch
Dukesterpro
Report this Post04-07-2025 11:06 AM Click Here to See the Profile for DukesterproSend a Private Message to DukesterproEdit/Delete MessageReply w/QuoteDirect Link to This Post
Put it down for 21 reccomendations for the luk kit. I use and abuse them with my 3.4 LQ1, fantastic clutch!
hnthomps
Total ratings: 51
Report this Post04-17-2025 03:08 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have used a SPEC Stage II clutch on my turbo 3.4 setup for bout 15 years and have been quite happy with it.
Nelson
