  CV axles and tie rod removal
CV axles and tie rod removal by saving_rossi
Started on: 04-15-2025 11:14 PM
Replies: 11 (126 views)
Last post by: Vintage-Nut on 04-18-2025 10:49 AM
saving_rossi
Report this Post04-15-2025 11:14 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
1985 V6 SE, automatic. Working on getting transmission off, I’ve got the cradle out and the last thing I need to do is get the axles out of the hubs and the transmission lifted.
But, I’m trying to get the outer tie rods off to get enough suspension movement—I have a tool to do it, but it’s just getting grease everywhere and not moving the tie rod.
Is there a way to remove the axles and transmission without removing the tie rod ends from the knuckle?
I ask too many questions on here. Lucky to have you people to pester when I get anxious about what I’m doing wrong.
IMSA GT
Total ratings: 253
Report this Post04-15-2025 11:42 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What tool are you using that's getting grease everywhere.....a pickle fork and hammer?
This might be a lot easier.
https://www.harborfreight.c...StoreCode=3473&gQT=2
[This message has been edited by IMSA GT (edited 04-15-2025).]
saving_rossi
Report this Post04-16-2025 12:33 AM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
This looks so much more useful. Yeah I was using a pickle fork and hammer, I’ll pick this up tomorrow.
Thank you
1985 Fiero GT
Report this Post04-16-2025 06:10 AM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I dropped my cradle, to disconnect the axle from the transmission (I left them in the hubs), I pulled the struts apart, and disconnected the inner tie rod, it's just bolted in place, not the press fit of the outer tie rod. To get the outer tie rod off, I just use a hammer on the nut partially threaded onto it
Total ratings: 259
Report this Post04-16-2025 06:48 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can disconnect the tierod from the inboard mount. That is just a single nut, and then you don't need to mess with the taper on the outboard end.
Vintage-Nut
Report this Post04-16-2025 09:18 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes as fieroguru mentioned...
When removing the tie rod ends from the knuckle...
Yeah I was using a pickle fork and hammer..
Don't be a caveman, use the proper tool which are listed in the service manual
{or equivalent}
[This message has been edited by Vintage-Nut (edited 04-16-2025).]
Filben
Report this Post04-16-2025 09:28 AM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
And the double hammer on the taper trick. Hit both sides of the taper on the knuckle with a hammer at the same time while theres some force pushing the tierod end out, usually falls right off unless its seized to hell and back. My VW dune buggy was seized solid and had to be cut off and drilled out.
montegut
Report this Post04-16-2025 11:08 AM Click Here to See the Profile for montegutSend a Private Message to montegutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Am I wrong but is this tool listed for $330 to $600?
Vintage-Nut
Report this Post04-16-2025 01:45 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, Kent Moore tools are 'big bucks' these days; I got the tool years ago 'used' at $40....
Search Equivalent Tie Rod End Tools like...
OEMTOOLS 25112 - $55
https://www.amazon.com/OEMT...table/dp/B0B64NFT56/
saving_rossi
Report this Post04-16-2025 11:47 PM Click Here to See the Profile for saving_rossiSend a Private Message to saving_rossiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ended up using the outer tie rod removing tool…rented it from AutoZone, got them both off in about two minutes. I’m so relieved. Transmission and axles are all out
Filben
Report this Post04-17-2025 08:10 PM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
A master tierod and balljoint pickle fork set works like magic on popping the CV axles out of the transmission. https://www.harborfreight.c...t-5-piece-63738.html
I have this one and it makes it a breeze to pop them out.
Vintage-Nut
Report this Post04-18-2025 10:49 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW - A pickle fork normally damages the rubber boot where the proper tool won't....
