First off what engine are you using with that computer that you intend to use. Is this this for the Fiero 2.8L engine or an engine swap. If this ECM is to control a 3100 Buick engine then you will need the original harness rewire it accordingly and combine it into the existing Fiero wiring harness, Then you will need to reprogram the ECM by changing the chip program by re-writing the code to suit the engine and your Fiero. You will need an editing program to do this and a programmer.
