  Think found headlight raise problem
Think found headlight raise problem by John W. Tilford
Started on: 04-18-2025 10:53 AM
Replies: 7 (109 views)
Last post by: Vintage-Nut on 04-19-2025 10:59 AM
John W. Tilford
Report this Post04-18-2025 10:53 AM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
When manually raising the problematic driver side headlight this morning I actually paid attention to an initial "screwed down too tight" feeling. The manual raise knob which turns counter-clockwise to raise the headlight was really tight at first, then felt free for a couple turns, then started raising the headlight with minimal effort. I compared to the almost always working fine passenger side manual knob. Was not nearly as "tight" when starting up as the driver side knob.
As an experiment when both lights were up and lit I turned them off. Both went down no problem. Then I checked the driver side knob: Same "too tight" resistance again. I turned the knob just far enough to get into the "feels free" zone and switched on the head lights. Both went up!
Is there a mechanical adjustment for how much the headlight travels down? Something I can experiment with? Maybe in the motor/gear assembly?
John W. Tilford
Report this Post04-18-2025 11:48 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
The free versus tight feeling could be because of damaged gears and / or broken up nylon pieces.
Vintage-Nut
Report this Post04-18-2025 12:03 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you replace the three Delrin cylinders in the motor?
Report this Post04-18-2025 12:32 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
John, this is what VintageNut is referring to:
For 1984-1986 Motors: https://www.fierostore.com/...0%20SINGLE&d=273&p=1
For 1987-1988 Motors: https://www.fierostore.com/...0%20SINGLE&d=273&p=1
It definitely sounds like the nylon (Delrin as VintageNut says) are broken up. They're sacrificial, and they eventually break up, which explains the "free" versus "tight" feeling in the gear. It's easy to fix... you just have to remove the motor, remove the gear plate, clean it out, and replace the nylon pieces (and I think you grease it too, I can't remember).
John W. Tilford
Report this Post04-18-2025 01:08 PM Click Here to See the Profile for John W. TilfordClick Here to visit John W. Tilford's HomePageSend a Private Message to John W. TilfordEdit/Delete MessageReply w/QuoteDirect Link to This Post
To all above, late last year I replaced the larger plastic cylinder (with the angled slots on its concave edge) because it had a totally worn away one spot on the edge. As if you'd taken a fine rat tail file the same diameter as the helical drive screw and filed off all the angled slots in that spot. Before that I had to quickly kill power at the battery (closest point I could find at the time) because of a non-stop rapid miniature machine gun sound after I'd turned off the lights and they'd gone down. Sure does seem the motor was running right past the normal higher load stopping point and grinding off the one spot on the edge of the gear.
And now I notice the manual knob was tighter on the driver side when the headlights were down. Which brings me back to the original questions. Is there an adjustment I'm missing for the full down position? Maybe the headlight control module is not properly sensing the increased load on the left headlight when it hits the full down position? Or not reacting properly?
I used Rodney's steel version of the larger cylinder. Also replaced the three plastic 'plugs' although the originals did not seem damaged at all.
Vintage-Nut
Report this Post04-18-2025 04:22 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perhaps *These* Links Might Help You....
Part 1 - http://www.youtube.com/watch?v=XuX6an9MJe0
Part 2 - http://www.youtube.com/watch?v=kZ8IeZWyUMY
And *This* Thread:
87 - 88 Headlight motor rebuild instructions
https://www.fiero.nl/forum/...060811-2-066668.html
[This message has been edited by Vintage-Nut (edited 04-18-2025).]
Total ratings: 328
Report this Post04-18-2025 10:12 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time is money and if its the early gen 1 motors we have no choice but to rebuild but if its the gen 2 (87-88) motors, I just purchase another brand new one for about $80. Easy replacement job and done..
Vintage-Nut
Report this Post04-19-2025 10:59 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
New {Not Remanufactured} CARDONE motors are $100 plus shipping on Rock Auto
https://www.rockauto.com/en...,headlamp+motor,1412
