  17 gal fuel cell
17 gal fuel cell by Josh86gt
Started on: 04-22-2025 03:06 PM
Replies: 9 (266 views)
Last post by: 1985 Fiero GT on 04-28-2025 10:21 PM
Josh86gt
Report this Post04-22-2025 03:06 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was sitting here pondering on how to potentially get more fuel in my fiero then I saw a 17 gallon fuel cell on summit racing I measured it and it should fit very well in the small storage compartment in the rear of the car I was wondering if anyone has ever tried to add a fuel cell in the rear as it would allow the car to hold close to 30 gallons of gas if you somehow found a way to also keep the original fuel tank
richard in nc
Report this Post04-22-2025 05:57 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
that might be good for a built car.most fieros including swapped cars get around 20 mpg which is over 200 miles range with the twelve gallon tank.
Filben
Report this Post04-22-2025 07:17 PM Click Here to See the Profile for FilbenSend a Private Message to FilbenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why? It would basically make your car a bomb if you get rear ended. It would add an extra 150#s to the very rear screwing up the weight distribution even more. Unless you live 250 miles from the nearest gas station why would you need 30 gallons of gas in such a tiny car? My fullsize chevy work van doesn't even have a 30 gallon tank.
[This message has been edited by Filben (edited 04-22-2025).]
Report this Post04-22-2025 09:00 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mmmm, doesn't sound like a very good idea to me....💥💥
1985 Fiero GT
Report this Post04-22-2025 09:03 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah no, do not put gas in the trunk, there's no point, it messes with the weight distribution, incredibly dangerous (sitting on top of the muffler), etc. I put a 5 gallon fuel cell in the front trunk, spare tire delete, it ended up being exactly the same weight (full of fuel) as the tire, jack, brackets, etc, and I have more space in the frunk now. I get 500+km on a "tank" now, drove from New Brunswick to Ontario, only stopped for fuel twice. It's "safe" (enough) as there's nothing hot up there, and it's fairly far back from the bumper, and nestled between frame rails, etc. there's storage space on each side under the flat floor piece, room for a quart of oil, can of fix a flat, small tire inflator, and a plug/patch kit, all hidden in the floor beside the tank, giving me a very clean look, without sacrificing driveability/peace of mind.
Report this Post04-22-2025 09:07 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gas tanks mounted in crumple zones is typically a very bad idea.
Mounting one up front and behind the front wheels would be better, but still not ideal.
If you combo averages 25 mpg, and you run the larger 87-88 tanks, then will get you a 225 cruise range, and that is about my bladder limit anyway.
Report this Post04-22-2025 09:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe that the gasoline tank in a Fiero was mounted in the middle of the car for safety reasons. My 3800Sc gets 29-30 hwy mpg. Even in mixed driving thats about 300 miles per tank. If you have a 2.5L with the five speed you can get almost 400-450 miles per tank. A 2.8L w a Getrag can get you mileage in the high 20's. Do you really need to add a fuel cell?
Years back the Ford Pinto was plagued with gas tank explosions from the rear mounted gas tank.
[This message has been edited by Dennis LaGrua (edited 04-23-2025).]
buddycraigg
Total ratings: 478
Report this Post04-23-2025 04:27 AM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Blah blah blah... Pinto
That was exactly what I was thinking.
reinhart
Report this Post04-28-2025 06:08 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like this setup. How does it plumb into the fuel system? Is it connected to your main tank? Do you have to fill both tanks separately when at the gas station?
1985 Fiero GT
Report this Post04-28-2025 10:21 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a vent line hooked into the evap line coming off the main tank, and I have a second pump hooked into the main tanks fuel return line, so when the main tank is empty, I turn the second pump on, and it transfers the fuel into the main tank while the engine keeps running off the main fuel pump, yes, both are filled separately.
