The Miura project begins by Archie
Started on | : 12-08-2007 07:13 AM |
Replies | : 834 (216217 views) |
Last post by | : Archie on 02-03-2023 02:01 PM |
May 9th, 2009
30+mpg Member Posts: 4061 From: Russellville, AR Registered: Feb 2002
kinda of like this?
10:49 PM
May 15th, 2009
Archie Member Posts: 9436 From: Las Vegas, NV Registered: Dec 1999
12:38 PM
May 18th, 2009
Erik Member Posts: 5625 From: Des Moines, Iowa Registered: Jul 2002
03:37 AM
May 22nd, 2009
12:04 PM
12:45 PM
May 26th, 2009
Austrian Import Member Posts: 3919 From: Monterey, CA Registered: Feb 2007
Wow! THIS is the engine that should go into the Miura project. https://www.fiero.nl/forum/Forum2/HTML/100795.htmlA true transverse V-12.  yes I know, I'm dreaming  , but it's a nice thought, ain't it? [This message has been edited by Austrian Import (edited 05-26-2009).]
01:28 AM
Jun 10th, 2009
jbuell Member Posts: 13 From: san antonio tx Registered: May 2007
Transplanting a V12 transversly into the Fiero is an impressive feat of creativity and engineering and I applaud his ability to do so. Unfortunately , from what I have seen regarding the tight clearances that already exist for this Miura fiberglass body over the Fiero chassis , I doubt the body could accomodate an additional 2 inches of chassis width and keep the tires inside the wheel wells . In addition , as others have commented , the LS3 provides a higher power to weight ratio than the BMW V12 and certainly benefits from availability of affortable aftermarket performance parts . Neverthelesss , I agree that a transverse V12 in a Fiero should be awarded very high marks for style points and engineering talent. Hope to see more of this amazing project on his thread.
05:05 PM
Jun 12th, 2009
kevin Member Posts: 2722 From: Elk Grove, CA USA Registered: Jan 2000
Archie, I agree with the ideas of the two posts above, concerning the possible V12 in your Muira. If not the BMW variety, perhaps the V12 out of a Jaguar? I do not know if this engine, or one of a different manufacturer, is of a smaller dimension. However, I was just wetting everybodies appetite on the idea we can all agree on. Can you at least consider it?  Cordially, Kevin
08:13 PM
| quote | Originally posted by kevin:
Cordially, Kevin |
I admire people who go outside the box to do something that hasn't been done before, or at least hasn't been done very often. After all, I was there 20 some years ago when I started putting SBC's into the Fiero. Several years ago, I did the same thing with the 6 speed swaps & the LSx swaps. There is a big difference between building any First Time Swap on your own car, when you get a working knowledge of every inch of the car & can prove out that swap AND Building the same First Time Swap for a customer who expects to take home a package proven thru the years. I've measured the length & width of a V-12 Jag. engine & it won't even come close to fitting inside the frame rails. While I enjoy reading about that BMW V-12 built, it's not a commercially viable alternative as yet. In fact as related to that type of installation into a customers' car it is 100% unproven. The development costs of making that V-12 a proven swap to put into a customers' car & work out all the issues that would come up would be much more than the engine that he has already chosen. Also, I don't know what a new BMW V-12 engine would cost but this customer doesn't want a used engine in his car. I could go on but that should answer your qusetion. Archie
11:48 PM
Jun 22nd, 2009
03:55 PM
04:25 PM
The interior shop that's going to upholster all the interior parts is located in San Antonio, TX. The 1st group of parts they will upholster are the complete dash & the full console. We had to test fit all the interior parts again. We had to make sure that there was a proper gap between the surfaces where the panels came together to allow for the thickness of the material they are going to use. We also had toplan to make sure that the interior re-assembly could be done with all the panels upholstered. So, gapping of the panels & planning how it would all go together was on us. _2.JPG) _2.JPG) _2.JPG) _3.JPG) _3.JPG) _3.JPG) We didn't like how the center console mated up to the center section of the dash so we put a large radius where the walls met. _2.JPG) The interior shop doesn't have Internet at the shop, so I had to write up instructions & print off about 30 pictures to show them how the interior all went together. ........
04:55 PM
Last but not least, we had to make some mounting brackets for the seats. The seats had already been upholstered some time ago. But the mounting brackets that came with them were not going to work because they mounted the seats too high in the car. _5.JPG) _1.JPG) We needed to move the rails up as close as we could to the bottom of the seat & reangle the seats to lean back a little more. So we made new brackets for them. _3.JPG) _3.JPG) _4.JPG) _2.JPG) _2.JPG) Now that the 1st set of interior panels are out to get upholstered, we'll try to get most of the bodywork done before they return. Archie ------------------
 Sig by Custom2M4
05:37 PM
Gokart Mozart Member Posts: 12143 From: Metro Detroit Registered: Mar 2003
gonna make molds?
06:13 PM
| quote | Originally posted by Gokart Mozart:
gonna make molds?  |
Nope
08:39 PM
Jun 24th, 2009
madcurl Member Posts: 21401 From: In a Van down by the Kern River Registered: Jul 2003
| quote | Originally posted by Archie:
_3.JPG)
Pardon me, but what are the two opening for?
09:50 PM
Will-Martin Member Posts: 1164 From: DFW, TX, USA Registered: Aug 2002
| quote | Originally posted by madcurl:
Pardon me, but what are the two opening for? |
Looks like speakers, pretty cool.
10:08 PM
On the real car they have vents in those locations.
We put little speakers in that location to replicate the vents.
Archie
10:54 PM
Aug 20th, 2009
gt40racer Member Posts: 75 From: Abu Dhabi, UAE Registered: Mar 2002
any updates?
06:37 PM
Aug 22nd, 2009
Sharkman Member Posts: 804 From: Sweden Registered: May 2004
Aug 29th, 2009
fourpoint9 Member Posts: 1058 From: Long Beach, WA, USA Registered: Feb 2004
Sep 9th, 2009
yellowstone Member Posts: 9299 From: Düsseldorf/Germany Registered: Jun 2003
I just read through the whole thread for the first time and I must say that I'm astonished. It's just a thing of beauty to see this project coming together. Congrats, Archie!
12:03 PM
Sep 16th, 2009
bubbajoexxx Member Posts: 1630 From: Ontario Canada Registered: Aug 2003
updates we need updates PLEASE
12:47 PM
Sofa King Member Posts: 929 From: Registered: Aug 2008
Hi A,
What vehicle did you get the armrest? Is is the same width as the Fiero armrest?
02:17 PM
Oct 6th, 2009
Speedster Junior Member Posts: 1 From: France Registered: Oct 2009
Hi, I'm Benoit from France, I follow your post, congratulation for your great work. I think your Miura body kit is derived from a Prova Design Miura kit because it has the same trouble with the windshield installation, it’s strange because Prova Design has molded an original Lamborghini Miura P400 S to make its molds in the 80’s You may install taillights from a Fiat 850 Spider, they are identical on the Lamborghini Miura P400 & P400 S. These taillights are remanufactured : http://mrfiat.com/  [This message has been edited by Speedster (edited 10-06-2009).]
04:59 PM
Oct 13th, 2009
05:41 PM
06:06 PM
Oct 14th, 2009
continuing...... Then we had to figure out how to get power roll up windows in the doors. We had to figure out the geometry & hardware to make the windows in the doors roll up & down evenly, securely & reliably. We needed the window to roll up along a line up the back inside edge of the door. The vertical height of the window opening is only about 2" lower than the vertical height of the body of the door. So we had to come up with window mounting & operating hardware that used as little vertical space as possible. We decided to use Fiero power window hardware because we were going to have to heavily modify any "Kit" we might have bought & we had plenty of the Fiero parts so we could scrap a few sets of them without any big loss. Here are a few pics of the mock-up. Locations & angles of the rails that the scissor arms ride in were very important to get the windows to ride up evenly & correctly. All this took time & experimentation. We moved them around quite a bit while we figured out how each changed affected the window movement. _3.JPG) _2.JPG) Once we had figures out the details, we glassed in 2 mounting bars inside the door. _3.JPG) _2.JPG) then we were able to bolt in the final mounting plates to the bars & make it all operational. _1.JPG) .JPG) _2.JPG) _1.JPG) _2.JPG) _2.JPG) _1.JPG) Archie [This message has been edited by Archie (edited 10-14-2009).]
11:57 AM
12:31 PM
Wow! What a build. I like the trunks space and trunk hinges.
01:05 PM
Me Too! I LOVE THIS BUILD!!!!
Hi Archie, what car did you get the glovebox from? Are the dimensions similar to the original Fiero?
02:01 PM
Oct 15th, 2009
The hinges are from the rear hatch on an old XKE Jag. Coupe. | quote | Originally posted by Sofa King:
Hi Archie, what car did you get the glovebox from? Are the dimensions similar to the original Fiero? |
It's wider that the Fiero console is. It's from the back seat of a new VW, I can't remember exactly which one. The customer bought it & sent it to me. It is identified in one of the earlier posts in this thread. Archie
07:59 AM
Boogaloo Member Posts: 422 From: South Miami,Fl Registered: Sep 2009
Archie you and your staff ,never cease to amaze by outdoing your last creation and you are up there with the best of builders,more props to you for the inspiration you have given us thru the years .
11:13 AM
As you can see, I've got a lot to catch up on. In this view the headrests will mount into the half-round tube just under the rear window opening. The sanding block in the rear window represents the rear window glass. So we'll need headrests that have the mounting posts as far back as we can get..... _3.JPG) The customer bought some new headrests on EBay & had them sent to me. _4.JPG) The color doesn't match perfectly, so we know they'll have to be re-upholstered. We will be reshaping them before we send them out for covering. _3.JPG) Getting an idea if they can be fitted.... _4.JPG) _3.JPG) They'll have to be cut down a bit, but they'll work. We'll do that later when we fab. & fit the rest of the interior parts  ........ [This message has been edited by Archie (edited 10-15-2009).]
11:23 AM
12:17 PM
02:05 PM
05:27 PM
Simply beautiful Archie  and a  Please keep it coming... Cordially, Kevin [This message has been edited by kevin (edited 10-15-2009).]
06:05 PM
Oct 16th, 2009
Cordially, Kevin
Thanks, Kris & Rob are the guys making this happen. Archie
11:45 AM
