  newest project (Page 60)
This topic is 78 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78
newest project by bubbajoexxx
Started on: 09-12-2003 06:18 PM
Replies: 3111 (375603 views)
Last post by: Trinten on 04-23-2023 11:02 PM
Total ratings: 259
Report this Post12-01-2009 08:48 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Fiero2m8:
3. Today I picked up the hub bearing assemblies to use in the 88 front suspension swap.
These units will be modded to fit the 1988 Fiero spindles and will also accept the Corvette rotors and bolt pattern.
They are AC Delco Hub Bearings from an 85 S10 4X4 - Special thanks to Bubbajoe who is engineering this custom mod.
I would love to know more details about this mod and curious if it would work for the rear of an 88 as well.
bubbajoexxx
Total ratings: 112
Report this Post12-01-2009 04:56 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ryan call me have the numbers for you
Fiero2m8
Report this Post12-03-2009 05:53 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update for fieroguru:
After some more R&D we are going to mod Bearing #513009 instead due to its smaller size 2.79" vs. 88 spindle of 2.74"
Timken or FAG #513009
Cross Ref #7466902 7470539 7470540
Non-Drive (FWD)
REAR w/Disc Brakes
Non-ABS
Fits:
1979-1985 Buick Riviera
1979-1985 Cadillac Eldorado
1980-1985 Cadillac Seville
1979-1981 Oldsmobile Toronado
1982-1985 Oldsmobile Toronado
http://www.alibaba.com/prod...eel_unit_513009.html
RCR
Total ratings: 102
Report this Post12-04-2009 07:13 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
OK Ryan...Let's see how that 88 front is being adapted...
Bob
Fiero2m8
Report this Post12-08-2009 12:08 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
Nice to hear from you - I'm not holding out, just waiting om the new bearings...stay tuned.
RCR
Total ratings: 102
Report this Post12-08-2009 06:43 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey again, Ryan...Hope all is well...
I've been looking at different options for modifying/improving my front suspension, brake upgrade, etc. My biggest motivation is the brake upgrade with a larger bolt pattern. The 84-87 rotor will not support anything much larger than the 5x100 and I really didn't want to go through the process Bubbajoexxx did with yours. Replacing it with an 88 might be an option, so I am curious as to how you go about it and what may be involved.
Bob
[This message has been edited by RCR (edited 12-08-2009).]
Total ratings: 259
Report this Post12-09-2009 10:55 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Non-Drive (FWD)
REAR w/Disc Brakes
Non-ABS
So how much larger was the S10 wheel bearing than the 88 upright hole?
The new bearing uses a rectangular flange vs. the triangle and looks to have a much greated distance from the wheel flange to bearing mounting surface, so I am curious about what modifications will be done to bolt it up. I have spent hrs upon hrs researching wheel bearing application for something with a 3 bolt flange. If there was one that could be pressed apart (like the bearings for the drive wheels), then you might be able to disassemble the bearing and mount it on the back side of the upright and then reassemble - this will help offset the extra distance between the bearing flanges.
Fiero2m8
Report this Post12-09-2009 08:24 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
Why don't you just buy my old setup and bolt it on your control arms?
You'd be done the upgrade in an hour...
[This message has been edited by Fiero2m8 (edited 12-09-2009).]
Fiero2m8
Report this Post12-09-2009 08:37 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Member since Feb 2006
It was over 3 inches - It can be made to work on 84's (Bubbajoe's done it before) but not 88's as the spindle hole is smaller.
The Cadillac hub bearings were too much money for me in Canada so I returned the S10 bearings and am shopping for these off eBay here:
http://cgi.ebay.ca/ws/eBayI...geName=STRK:MEWAX:IT
Yes making a new flange to adapt to the 88 spindle will be required, but that's relatively easy to do out of 1/2" plate steel.
We are going that direction as you stated above unless...
It's possible to make a hybrid out of the new Cadillac hubs and the old 88 Fiero hubs as they do come apart.
Ryan
RCR
Total ratings: 102
Report this Post12-10-2009 06:01 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Now where would the fun be in that??
Bob
Total ratings: 259
Report this Post12-10-2009 06:40 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
unless...
That would be so cool if it happened to work out!
I scored a new set of the S10 wheel bearings from an ebay liquidator for $25 + shipping to do a closer check and satisfy my curiousity... I have a couple of sets of 88 uprights front/rear and would love to upgrade to the 4 3/4 pattern.
Fiero2m8
Report this Post12-22-2009 09:10 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey the Cadillac hub bearings finally arrived today...here's how they measure up vs. the 88 Fiero hub bearings
yashmack
Report this Post12-22-2009 11:53 PM Click Here to See the Profile for yashmackClick Here to visit yashmack's HomePageSend a Private Message to yashmackEdit/Delete MessageReply w/QuoteDirect Link to This Post
oh my god
i remember reading this thread a few years back before i stopped frequenting the site and how unfinished the car was then
this car has come sooo far
this is an incredible mod, its amazing to see how this car has come to life
bubbajoexxx
Total ratings: 112
Report this Post12-23-2009 06:24 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
measure the length of the housings the others mean nothing
Fiero2m8
Report this Post12-23-2009 08:32 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Caddy 2.36"
Fiero 1.94"
bubbajoexxx
Total ratings: 112
Report this Post12-24-2009 01:24 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
perfect they are swapable
Total ratings: 259
Report this Post12-24-2009 04:50 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let the bearing disassembly begin!
Fiero2m8
Report this Post12-26-2009 11:57 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bubbajoe, if you're around I'll drop them by Monday or Tuesday.
Ryan
bubbajoexxx
Total ratings: 112
Report this Post12-26-2009 12:15 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok
Fiero2m8
Report this Post12-26-2009 12:54 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update...
More teardown completed as the Porsche 901 transaxle is going to be refreshed and upgraded.
Coilovers and axles removed:
The design allows the transaxle to be easily removed from the chassis with motor in place:
Part of the plan is to upgrade the pressure plate:
The way everything adapted to the Northstar is quite ingenuis:
Yes that is a Christmas tree stump providing balance support with a floor jack:
While the transaxle is being attended to, the motor will also get some attention this off season...
Eau_Rouge
Report this Post12-27-2009 01:18 PM Click Here to See the Profile for Eau_RougeSend a Private Message to Eau_RougeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Ryan, I think I'll take you up on your offer. let me know when you'll be intstalling the 88 front subframe and I'll gladly make the trip so see the car.
Maybe while I'm there, hopefully you'll be able to tell me how to bleed my brakes....took my car in for service a few weeks back (before the snow hit) to have my clutch hyraulic system flushed and ended up with spongy brakes...feels like there's air in the lines now and I'd like to fix this myself.
Cheers,
Cesar
Fiero2m8
Report this Post01-18-2010 08:32 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bad news is progress on the project is moving slowly.
Good news is slow progress is because I'm busy at Samsung as the National Service Manager.
So I decided to sub out some of the overhaulin'...
Here are the disassembly pics of the 35 year old Porsche transaxle that is due for a refresh:
[This message has been edited by Fiero2m8 (edited 03-05-2010).]
Total ratings: 259
Report this Post01-19-2010 08:28 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats on the new job! Any update on the bearing mods?
Fiero2m8
Report this Post01-20-2010 07:56 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Guru - Bearings are at Bubbajoe's, he agreed to post pics here as progress is made.
Fiero2m8
Fiero2m8
Report this Post01-23-2010 07:54 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
It felt good to work on the project today.
As you can see the Northstar was dismantled and removed to address the piston ring compression:
IVANNATINKLE
Report this Post02-03-2010 12:25 PM Click Here to See the Profile for IVANNATINKLESend a Private Message to IVANNATINKLEEdit/Delete MessageReply w/QuoteDirect Link to This Post
have you had a chance to install the new cradle yet?
Fiero2m8
Report this Post02-06-2010 01:57 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Rear cradle is in - front cross member is not.
If you need pictures or measurements let me now.
Here's a picture of all the internal parts replaced in the 5 speed transaxle rebuild:
IVANNATINKLE
Report this Post02-06-2010 02:00 PM Click Here to See the Profile for IVANNATINKLESend a Private Message to IVANNATINKLEEdit/Delete MessageReply w/QuoteDirect Link to This Post
lets see some pictures!! how have you had a chance to move with the new cradle in yet? or is the motor still in rebuild?? ps. hows the trans holding up??
Fiero2m8
Report this Post02-23-2010 04:33 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes new cradle was in prior to engine / trans rebuild.
Here are some pics of the latest project parts:
New Kevlar clutch:
Modified Pressure plate to handle torque of the Northstar:
Machined Flywheel to correct clutch clearance and flywheel ring refreshed:
All this custom work/parts are from EuroDrive Clutches in Burlington Ontario.
http://www.euro-drive.com/
[This message has been edited by Fiero2m8 (edited 02-23-2010).]
Fiero2m8
Report this Post02-27-2010 07:16 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Today I got some time to work on the spaceframe...
The glass was masked off:
I removed the headlamps and the rest of the hardware I wanted prior to paint:
Since the front compartment is my only luggage area, I decided to enlarge the area:
Next I used engine degreaser to clean the whole frame.
Since there is hardly any rust, I'm going to use etching primer instead of my POR-15 as it won't stick well:
Now I'm ready for my three steps:
1) spray etching primer
2) brush on gloss black rust paint
3) spray final coat of gloss rust paint
Fiero2m8
Report this Post03-09-2010 08:28 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Some update pics from Saturday...
Sorry for the slow progress, as I only have time to work on my baby one day a week.
Fiero2m8
Report this Post03-10-2010 08:13 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Northstar is completely disassembled ready for rebuild:
Crank has been sent out for balancing and awaiting parts to arrive.
motoracer838
Total ratings: 83
Report this Post03-13-2010 10:01 AM Click Here to See the Profile for motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, Its been a while since I've checked in on this project, I had no idea that you had gone this deep into the car. Keep up the good work.
Joe
Fiero2m8
Report this Post03-15-2010 08:44 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Joe
Thanks Joe, after proving last year that the the engineering is near completion I decided to restore everything to higher standards since I plan to keep this one awhile.
Here are a few more pictures from the weekend of the front half of the space frame painted:
Fiero2m8
Report this Post03-15-2010 07:23 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
New Hi Torque gear reduction starter for Porsche transaxle arrived today.
motoracer838
Total ratings: 83
Report this Post03-16-2010 04:58 PM Click Here to See the Profile for motoracer838Send a Private Message to motoracer838Edit/Delete MessageReply w/QuoteDirect Link to This Post
Question for Bubbajoe, do you still have the modified Pontiac 6000 uprights? I have a project that needs the 5 on 4.75 bolt pattern that setup allows, I figured that it would be easier to buy the parts you have than doing it over.
Joe
Fiero2m8
Report this Post03-21-2010 02:15 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
The panels are getting closer to paint and half are primed:
Indy Northstar-Stretch ~ LT1-NOS Roadster
Fiero2m8
Report this Post03-25-2010 07:04 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Before and after pictures of the floorpan being cleaned and repainted:
Fiero2m8
Report this Post03-29-2010 12:59 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
On the weekend I received the elusive 88 intermediate steering shaft I've been looking for the past year.
Now I have most of what I need to install the 88 front suspension into the 84 indy chassis
Stay tuned...
ezramore
Report this Post03-30-2010 03:30 PM Click Here to See the Profile for ezramoreSend a Private Message to ezramoreEdit/Delete MessageReply w/QuoteDirect Link to This Post
amazing what a little paint will do
