  newest project (Page 64)
This topic is 78 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78
newest project by bubbajoexxx
Started on: 09-12-2003 06:18 PM
Replies: 3111 (375603 views)
Last post by: Trinten on 04-23-2023 11:02 PM
johnyrottin
Total ratings: 85
Report this Post01-01-2011 10:01 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this car put back together with that beautiful black paint on all the panels???
RCR
Total ratings: 102
Report this Post01-02-2011 09:33 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by bubbajoexxx:
there are none the rads are in the rear side pannels of the car
Shoot...That makes more sense...I forgot about that.
thanx, Joe...
Bob
Fiero2m8
Report this Post01-07-2011 05:46 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok I am in Calgary this week but I got the electric vacuum pump installed for the brake system.
It fit nicely out of sight but accessible so I could bolt the trunk into place.
Also the decklid, spoiler and several small parts are painted leaving only the rear clip and roof to finish bodywork prep and paint.
Fiero2m8
Report this Post01-07-2011 05:50 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Member since Feb 2006
Nope this build thread is usually within a couple days of current status meaning I have to do something to post more pics.
No history lesson or holdouts here...I use the thread as motivation to keep going on the project.
Indy Northstar-Stretch ~ LT1-NOS Roadster
ezramore
Report this Post01-12-2011 09:32 AM Click Here to See the Profile for ezramoreSend a Private Message to ezramoreEdit/Delete MessageReply w/QuoteDirect Link to This Post
my favorite part of any build is when you start seeing the final picture. Looks like its going to be an awsome vehicle. Wonder if you could sell the design to GM if they would manufacture them. What are you going to do with your time when its all done?
Fiero2m8
Report this Post01-18-2011 11:51 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Small update that condenser/fan are mounted in car:
Going to shift focus to reinstalling the powertrain next...
Fiero2m8
Report this Post01-23-2011 08:51 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, Time to dress the motor.
Need to start with the front since it's not easily accessible once on the cradle.
First thing I realized was it's been over a year since I took the engine apart so it's a bit of a head scratcher.
However I'm not worried because I've got Bubbajoe and pictures from this thread to use as reference.
If you're into this build and have time to pull dressed engine pics, please use page 55 as a Table of Contents to find them for me.
Here's the rebuilt .20 over 2001 Northstar from hibernation:
Once unwrapped I finished painting the block with alumi-blast:
The valve covers receive new rubber gaskets so they can be used installed to keep the top end clean:
I used a wire wheel to clean the paint off the reluctor wheel:
Next I noticed that the harmonic balancer may not be neutral balanced? See holes on one side - not sure if this is a problem as the crank was balanced internally:
The crankshaft is keyed but the balancer is not, it can be bolted on in any position:
I am going to use my dial indicator to find TDC #1 cylinder (left front) and use this guage to align the pickup sensor:
The reluctor wheel can also be mounted in any orientation (held by the crank bolt) so it doesn't matter where the balancer is in relation:
bubbajoexxx
Total ratings: 112
Report this Post01-23-2011 11:26 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
you need to have the pickup on the engine before you tie down the reluctor wheel at top dead centre with the notch lined up with the picup coil
the balancer is neutral ballance as the hole you see is the palce where weight was removed to make it balanced
[This message has been edited by bubbajoexxx (edited 01-23-2011).]
Fiero2m8
Report this Post01-24-2011 11:32 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
you need to have the pickup on the engine before you tie down the reluctor wheel at top dead centre with the notch lined up with the picup coil - OK 1) MOUNT SENSOR 2) SET TDC 3) TIGHTEN ALIGNED WHEEL WITH SENSOR POINTING AT NOTCH
the balancer is neutral ballance as the hole you see is the palce where weight was removed to make it balanced - PERFECT JUST DOUBLE CHECKING
madcurl
Total ratings: 314
Report this Post01-24-2011 06:28 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
What type of gaskets are you using?
Fiero2m8
Report this Post01-25-2011 11:41 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey MadCurl,
For gaskets and seals I have a combination of OEM GM and Victor Reimz depending what it was for...
[This message has been edited by Fiero2m8 (edited 01-25-2011).]
madcurl
Total ratings: 314
Report this Post01-25-2011 04:49 PM Click Here to See the Profile for madcurlSend a Private Message to madcurlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey MadCurl,
Thanks. I was looking at the injector 0-rings.
Fiero2m8
Report this Post01-31-2011 09:37 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
My son Andrew is 14 now so he's more receptive to learn about working on cars.
He helped bolting on engine mounts and finding TDC for me this week.
I'm hoping to finish the front engine accessories tonight so the engine can go back in the chassis soon.
Fiero2m8
Report this Post02-03-2011 10:45 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mechanical timing is set (trailing edge of 11th took after notch turning clockwise).
Gap is 0.025" with no runout and crank bolt torque is 37ft/lbs + 120 degrees:
New compressor is a five rib and smaller diameter pulley.
Since I was reducing 2" in length from 71 to 69, I modified a 6 rib belt commonly used on GM 2.8V6 or Jeep 4.0L:
Here is the installed belt after all pulleys and tensioner adjusted:
Next I mounted to cradle using 10.9 grade hardware and energy suspension poly mounts:
Ready to slide under chassis and lower frame to cradle
Fiero2m8
Report this Post02-06-2011 11:42 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Report this Post02-08-2011 12:08 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Work progressing on the rear suspension reassembly:
Drilled out rubber bushings for coilovers as they were sloppy after powdercoating.
Poly bushings installed in LCA:
Coilovers and spindles:
Fiero2m8
Report this Post02-08-2011 11:44 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Attention thread newbies - Table of Contents updated on page 55
Looky what just arrived...
Fiero2m8
Report this Post02-10-2011 11:33 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Report this Post02-15-2011 09:11 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
The intake manifolds are cleaned and installed:
Fiero2m8
Report this Post02-16-2011 04:48 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Last night progress was slow as I spend 3 hours adjusting the exact position (square and level) of the engine in the engine bay.
It was my first anal rententive task in quite a while but I've got to be happy with everything or it will haunt me...
Tonight's plan is more ambitious as I'm installing the adapter plate, flywheel, clutch, pressure plate and transaxle.
Fiero2m8
Report this Post02-19-2011 10:30 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well more progress made in the engine bay.
I realized that previous transmissions I'd installed were all automatics (GM and BMW) so I did some research first.
I used this well documented tech article with photos from pelican parts on changing a clutch in the Porsche 914
http://www.pelicanparts.com..._clutch_replace1.htm
They also have a handy checklist I printed to make sure steps were in the right order and I didn't miss any
http://www.pelicanparts.com...eplace_checklist.pdf
The Porsche 901 transaxle is by far the lightest I've ever worked with at a featherweight 89lbs, so this was easy to do myself by hand.
Cleaned and installed the adapter plate
Rebuilt Flywheel is neutal balanced that I bolted on at 60ft/lbs
(Porsche recommends 79.5ft/lbs but they use 5 large bolts while my adapter uses 8 small bolts with threadlocker)
Next is the new Kevlar clutch (thanks Bubbajoe for the extra input shaft to use as a clutch alignment tool - worked perfectly
Make sure to clean everything well as the flywheel and pressure plate have anti rust coating on them
Next goes the pressure plate onto the 3 flywheel locating pins with 6 bolts torqued to 14.5ft/lbs
The test fit went pretty smooth - slide onto studs, ensure level and slowly turn flywheel by prying tooth with a sflat screwdriver
When splines are aligned it moves slightly and you can push the rest of the way home
After a test fit, measured the throw out arm clearance and going to shim the pivot bolt before final installation
Make sure to add some grease to the end of the input shaft before reinstall
This long weekend I'll be installing more of the engine accessories...
Fiero2m8
Report this Post02-20-2011 09:42 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
After a successful test fit of the transaxle, I removed it to adjust the throwout bearing arm
I shimmed the pivot ball with a washer to decrease the endplay from 1" to 1/2"
While off the transaxle got a topcoat of high heat aluminum paint
I adjusted the drivetrain to be square and level as an assembly then torqued everything in place
Dellorto carbs are painted and installed
Progress is slow but steady...
Fiero2m8
Report this Post02-21-2011 09:04 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Stat Holiday Family Day in Ontario today so I did some of the "fun" stuff this afternoon
Polished and mounted the velocity stacks
Installed the stainless filters I got on eBay
Mounted oil pan brace and oil filter
Torqued the ceramic coated headers to 18ft/lbs
OHNIKO
Report this Post02-24-2011 10:52 AM Click Here to See the Profile for OHNIKOSend a Private Message to OHNIKOEdit/Delete MessageReply w/QuoteDirect Link to This Post
JUST WOW!...
we want to see it running & on the road by beginning of April at the latest!
lol, there's your motivation; you now have a deadline, as we'd like to see it come along to Watkin's Glen in April...
Fiero2m8
Report this Post02-25-2011 09:06 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by OHNIKO:
JUST WOW!...
Yes that's the ambitious goal.
Let me know the actual date of Watkins so I can co-ordinate a week vacation request leading up to it - I think it's going to be that down to the wire...
Last night I got the slave cylinder, axles and rest of the exhaust mounted:
Need to have it running in a couple weeks time if I am going to have the body back on in a month.
Right now it looks like this so I've got a ways to go:
Suspension and drivetrain are done so really engine plumbing, wiring and new brake system are planned prior to body reinstall.
Dave E Bouy
Report this Post02-26-2011 12:30 PM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fabulous looking work work Ryan. Can't wait to see it up close.
Dave
Gokart Mozart
Total ratings: 159
Report this Post02-27-2011 03:38 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Peace of mind is worth every millimeter!
Danyel
Total ratings: 171
Report this Post02-27-2011 10:59 PM Click Here to See the Profile for DanyelClick Here to visit Danyel's HomePageSend a Private Message to DanyelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Totally blown away !!!! Just one word..... WOW !!!!
http://www.tylerstoy.com
Fiero2m8
Report this Post02-27-2011 11:23 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dave
Thanks Dave, I'm looking forward to cruise season!
Fiero2m8
Report this Post02-27-2011 11:30 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Yes Dan, I felt the same way yesterday when taking the extra hour to polish the 18 valve cover bolts before torquing them down to 106 in/lbs.
Fiero2m8
Report this Post02-27-2011 11:42 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Thanks Danyel, nice to hear from you.
Today I installed the Willwood adjustable brake proportioning valve.
First I bleed the master cylinder while mounted in the car
All the brake lines have been replaced
Brake pressure switch was spliced in
Now I'll be able to dial in the optimal front / rear brake bias
War Hammer
Report this Post02-28-2011 09:47 AM Click Here to See the Profile for War HammerSend a Private Message to War HammerEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is so clean!
Fiero2m8
Report this Post03-01-2011 11:37 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by War Hammer:
It is so clean!
Thanks, your widebody is going to be sweet too.
On with the show...
Yesterday's project was supposed to be simple - install this
GM parts counter in GTA are rude compared to Niagara as they were demanding a VIN to order parts...anyways here's the part numbers for OEM gaskets:
Used my own build thread for reference pics on the bolts then realized transaxle needed to come off again for access to bolt near starter:
I'm sure Bubbajoe mentioned this at some point but anyways now I'm a pro at re/re the transaxle
I'm using the GM service manual for reference so these bolts are torqued to 18ft/lbs or 216in/lbs (someone with a Northstar will google this and find my thread)
Next, I'll be picking up some more body panels including the hood.
Fiero2m8
Total ratings: 237
Report this Post03-02-2011 08:20 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think it would hurt starter support much if you cut out enough of that ring to clear the bolt/housing.
bubbajoexxx
Total ratings: 112
Report this Post03-02-2011 05:36 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
no you can not cut this out as there is a cut out right behind the ring to clear the water log on the starter hub
Total ratings: 237
Report this Post03-02-2011 10:55 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see that it's been cut out for the waterpump bolt. I don't think there would be any adverse consequences of cutting it more, considering that it seems to have studs on either side of it.
Total ratings: 237
Report this Post03-02-2011 11:04 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jun 2000
FYI, #1 is in the right bank...
Total ratings: 237
Report this Post03-02-2011 11:08 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Where did you get that torque spec? Seems excessive for 8mm bolts...
bubbajoexxx
Total ratings: 112
Report this Post03-02-2011 11:47 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
He did not ask me what the torque was for the flywheel but it is 45 ftlbs on 8 mm 12.9 thats the yeld for that spacific bolt and for the stock bolts its the same
The porsche bolts he is refuring to are 13 mm x 1.25 , 12.9 and they use 75 ftlbs yeld
[This message has been edited by bubbajoexxx (edited 03-02-2011).]
bubbajoexxx
Total ratings: 112
Report this Post03-02-2011 11:56 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bubbajoexxx
Member since Aug 2003
if it was aluminum it would not hurt to much but the case is magnesium and the torque output of the starter is extreemly high turning an engine with 11
:1 compresson so the load is transfered to the case and the starter ring takes that force as the starter has a collar that fits tight in the starter ring
