  newest project (Page 67)
This topic is 78 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78
newest project by bubbajoexxx
Started on: 09-12-2003 06:18 PM
Replies: 3111 (375603 views)
Last post by: Trinten on 04-23-2023 11:02 PM
Fiero2m8
Report this Post04-19-2011 12:16 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Benja:
Unbelievable. Just spent almost the whole day going through this thread. My body hurts just from reading all this, I can only imagine the pain of building it. How many years? Hours? Dollars? Amazing, my hat is off to you both, along with my shirt, shorts and rhinestone studded thong.
Ben
Thanks Ben,
newest project by bubbajoexxx Started on : 09-12-2003 06:18 PM
Replies : 2639 (279174 views)
Last post by : Fiero2m8 on 04-19-2011 02:21 AM
I remember reading the whole thread as well and can relate.
We don't keep track of hours because it's a hobby, but please don't remind me about the dollars
Update, the intakes have been resealed to eliminate vacuum leak:
Fiero2m8
Report this Post04-20-2011 01:53 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've wondered about the coolant tube crossing the engine bay. It's a bit distracting. What about running it along the side and rear and painting it black?
Thanks to donation from Bubbajoe, this mod request is now officially on the list
BtotheB
Total ratings: 77
Report this Post04-20-2011 11:02 AM Click Here to See the Profile for BtotheBClick Here to visit BtotheB's HomePageSend a Private Message to BtotheBEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is looking really good. You'll have to post on here what shows you're attending this year, I'd really like to check this out in person when it's complete.
Brad
Fiero2m8
Report this Post04-21-2011 11:59 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Brad
Thanks Brad, will do.
BTW, Table of Contents on page 55 is updated to end of page 66.
Mystik
Report this Post04-21-2011 01:32 PM Click Here to See the Profile for MystikSend a Private Message to MystikEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is actually the first time I'm seeing this build... I'm fairly new to the forums but I'm loving this build.
I'm also in ontario so 2m8, let us know when you're going to be showing up to events so we can plan to come check out this beast, when you're ready.
Awesome car.
Total ratings: 259
Report this Post04-21-2011 03:38 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any chance you could get Bubbajoe to add the table of contents to the first post on page 1... I sometimes forget which page it is on and have to go searching for it.
Gokart Mozart
Total ratings: 159
Report this Post04-21-2011 07:59 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
bubbajoexxx
Total ratings: 112
Report this Post04-21-2011 08:00 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
DONE
Benja
Report this Post04-23-2011 12:32 PM Click Here to See the Profile for BenjaSend a Private Message to BenjaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by bubbajoexxx:
DONE
Awesome! Thanks!
Fiero2m8
Report this Post04-26-2011 12:48 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Couple questions for Bubbajoe:
1. What do these wires connect to? (comes out of frame and then splits to red plug and red wire - can't remember if I cut it or it dead ended in the wire loom)
2. Where can I buy a replacement linkage? (it was seized and it broke when I tried to adjust it shorter...looks like something from a hobby shop)
Working on carb tuning, fixed a small fuel leak on the return line.
I have vacuum at the PCV valve now pulling evenly from the 8 ports - if I measure and adjust it, any ideas how much vacuum the pcv needs at idle?
Also I started balancing idle airflow on the 8 barrels using the unisync guage.
7 of 8 are close and just need balancing between barrels per carb, but cylinder #8 the airflow is high and bouncing up and down.
Cylinder 7 is steady and a little low so I can't fix it with the idle speed screw for 7 and 8.
Also they are outside the adjustment range of the air bypass balancing screws on 7 and 8.
Going to check the fuel pressure as I suspect it's at 4psi and that is the first carb after the regulator.
Dellorto book says it should be 3 psi and anything over 3-1/2 will cause spillover - hopefully it's that easy.
If not that, I'll be checking for partially plugged idle jet circuit, vacuum leaks, spark plug condition etc.
Once the idle speed is done, I'll be adjusting mixture on each barrel to find the sweet spot between lean snaps and rich smoke.
I already adjusted from 3 turns out for initial startup to 1-1/2 turns out (leaner).
For dialing in the initial timing and 3000-8000rpm not sure how I'm going to baseline tune that without a dyno.
Book suggests 12 inital and 24 degrees progressive as baseline settings for a SBC while I was running 0-4 initial and 18-22 previously on the Northstar.
Obviously I don't want hard starting or detonation, but enough advance to get the best horsepower - any suggestions will be helpful.
Mostly I'm thinking out loud here and more reading and tinkering will help keep things going in the right direction.
I realize that most Fiero owner don't have to tune 8 cylinders individually but hey if you were at the 25th, you can vouch that the exhaust note is uniquely worth it
bubbajoexxx
Total ratings: 112
Report this Post04-26-2011 02:45 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
1. What do these wires connect to? (comes out of frame and then splits to red plug and red wire - can't remember if I cut it or it dead ended in the wire loom) [not used for cruze control]
2. Where can I buy a replacement linkage? (it was seized and it broke when I tried to adjust it shorter...looks like something from a hobby shop) no they are throttle hem joints may have 2 left here
I have vacuum at the PCV valve now pulling evenly from the 8 ports - if I measure and adjust it, any ideas how much vacuum the pcv needs at idle? [12 to 18 inches]
7 of 8 are close and just need balancing between barrels per carb, but cylinder #8 the airflow is high and bouncing up and down. [check the air bleed may be pluged with paint ]
Also they are outside the adjustment range of the air bypass balancing screws on 7 and 8.[check srew by removing it and make sure the bleed hole is not pluged]
Book suggests 12 inital and 24 degrees progressive as baseline settings for a SBC while I was running 0-4 initial and 18-22 previously on the Northstar.10 and 28 for nstar max power total 38 degrees at 7 thou
Fiero2m8
Report this Post04-28-2011 11:47 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
More questions, inquiring minds want to know...
Plug and red wire goes to alternator - other two go to A/C compressor?
Coolant fans and guage are working currently - does polarity of these wires matter?
Is this plug also cruise control related or is it for something else (i.e. lighting) or not used?
doublec4
Total ratings: 150
Report this Post04-28-2011 03:46 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I could be wrong... but I think that plug was for the original electric trunk popper, and the trunk light. Don't think it was for anything else, unless thats a different plug?
bubbajoexxx
Total ratings: 112
Report this Post04-28-2011 05:46 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plug and red wire goes to alternator - other two go to A/C compressor? [ac]
Coolant fans and guage are working currently - does polarity of these wires matter?[yes ] one is light other is gauge
Is this plug also cruise control related or is it for something else (i.e. lighting) or not used? [cruze ]
Fiero2m8
Report this Post04-30-2011 12:21 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a video of the carb idle air balance issue on cylinder #8:
Since the problem couldn't be corrected with the air balance bypass screws, I removed the carb to bench reset the butterfly valves.
I removed, cleaned and the swapped their bores:
Then I used the 0.003" feeler guage to set the gap on the tighter barrel, then slowly bent the throttle shaft until both sides fit the guage like a glove.
Now I should be almost perfectly balanced and any final adjustment can be done with the air bypass balance screws:
Erik
Total ratings: 168
Report this Post04-30-2011 04:43 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
offset is moved out 1/8 of an inch for the corvette rotors and calipers but you can remove 1/8 from the bearing stop to retian stock offset
Is the hub circle size the same as the stock 88? The reason I am asking is I would like to use my current wheels which have the 57.1 mm hub centering circle and the 5x100 bolt pattern
Could a 5x100 bolt pattern be drilled on the caddy hub flange? I am desperate to do this mod if possible as my stock hub is getting noisy
[This message has been edited by Erik (edited 05-01-2011).]
Fiero2m8
Report this Post05-01-2011 01:56 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for spark plug recommendations (to install when I've got the air/fuel mixture sorted):
Stock is AC Delco double platinum 41-987 for a 2001 Northstar with 0.050" gap.
My setup varies from stock since I am using coil wires and carbs.
Gokart Mozart
Total ratings: 159
Report this Post05-01-2011 03:35 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.gminsidenews.com...t-spark-plugs-88660/
Document ID# 1396703
Subject: Information on New Spark Plugs and Gapping #03-06-04-060 - (10/24/2003)
Models: 2004 Buick Ranier
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
2004 Cadillac CTS-V
1997-2004 Chevrolet Corvette
1998-2002 Chevrolet Camaro
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche
2003-2004 Chevrolet Express, TrailBlazer
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon XL
2001-2004 GMC Yukon Denali, Yukon XL Denali
2002-2004 GMC Sierra Denali
2003-2004 GMC Envoy XL
1998-2002 Pontiac Firebird
2004 Pontiac GTO
2003-2004 Hummer H2
with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
bubbajoexxx
Total ratings: 112
Report this Post05-01-2011 06:00 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
wont work with his HPV 1 as it requiers a gap of 32 Thou 40 will cause problems he requiers stock GM AC Delco plugs
Fiero2m8
Report this Post05-02-2011 09:53 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ah yes when in doubt read the manual...HPV 1 manual says 32 thous for stock V8 and 30 for hi-performance street.
So I guess I need an AC Delco part number of a non-platinum plug that has the right specs for a Northstar (size and heat range) that I can gap to 30-32 thou.
In the meantime, I have reduced the idle jets from 58's to 52's and turned in the mixture screws to half turn out.
After engine running at operating temp for a while plugs are changing to a tan colour.
Fiero2m8
Report this Post05-02-2011 10:09 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Member since Feb 2006
With the carb reinstalled this time I've been able to balance all barrel to identical smooth airflow reading.
Only remaining issue is #8 barrel makes a whistling noise that sounds like an open vacuum cap.
When the uni-sync guage in placed on the velocity stack it mutes the sound.
Since only this barrel makes this noise, I think there is still something minor going on.
You might be able to hear it in this video:
Erik
Total ratings: 168
Report this Post05-03-2011 11:40 AM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have to order and pre pay for the caddy hubs so I would really appreciate it if you could measure the hub and let me know, thanks!
Total ratings: 259
Report this Post05-03-2011 11:53 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Per the timken website/catalog:
79-85 FWD (rear bearing) 513010: Wheel pilot diameter = 2.76"
Fiero rear wheel bearing 513011k: Wheel pilot diameter = 2.25"
Erik
Total ratings: 168
Report this Post05-03-2011 03:56 PM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! So it looks like I am out of luck using my current wheels
Fiero2m8
Report this Post05-03-2011 10:11 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry Erik I missed your post but yes guru is right the hubs are bigger along with the bolt pattern.
bubbajoexxx
Total ratings: 112
Report this Post05-03-2011 10:49 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
you have a small blockage on the idle air port a good run will clear it nothing to worry about
bubbajoexxx
Total ratings: 112
Report this Post05-03-2011 10:51 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
bubbajoexxx
Member since Aug 2003
told you you had a bent throttle shaft balance is good now
Erik
Total ratings: 168
Report this Post05-04-2011 01:13 AM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
No problem. Do you think the hub pilots have enough thickness to be machined down to 2.25?
Total ratings: 259
Report this Post05-04-2011 06:37 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do your wheels have a removable concentric ring? All my aftermarket rims came with them, so when I swap hubs, I just swap out the concentric ring on the wheel.
[This message has been edited by fieroguru (edited 05-04-2011).]
Fiero2m8
Report this Post05-04-2011 09:29 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it just needed a bench tune as you said - another + for bubbajoe
Ok I'll move on to other stuff and keep an eye on it after some use
I'd say not a 1/2" look at the picture:
Last night I was working on the stainless rad hoses:
There is a local hydralic hose place that I going to have the one end resealed on both hoses now that I've cut them to proper length:
Routing with look something like this:
This is the highest point in the system their was no fluid in the hard crossover pipe - a little concerning?
Since the other hose connects to the bottom of the passenger rad I drained the DEXCOOL from the system in preparation for the swap.
bubbajoexxx
Total ratings: 112
Report this Post05-04-2011 10:56 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
keep the hose well clear of the exhaust remember its teflon lined and will melt at 300 degrees
Erik
Total ratings: 168
Report this Post05-05-2011 03:34 AM Click Here to See the Profile for ErikSend a Private Message to ErikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes they do except for one which was a shipping error. I just slighty reamed it out and it fit so, I measured the OD of the ring they are 2.88 so its just a matter of getting concentric ring, thanks for the heads up.
But, I will still have to change the bolt pattern spacing to 5x100 hopefully there is room to do so. If you can, please look and tell me if you think that is feasible before I order the hubs, thanks again!
RCR
Total ratings: 102
Report this Post05-05-2011 08:07 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
@ Erik:
Erik, I had asked Joe about finding a hub that used a 5x115mm hub instead of the 5x4.75" that Ryan used. He recommended: 86 and up caddy rear bearing buick riv olds 88 5X115
This might have a smaller flange that you can work with.
Bob
Gokart Mozart
Total ratings: 159
Report this Post05-05-2011 09:06 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
What about using exhaust hangers to hold the tube away from other parts. I'm sure you can mount them upside down so the tube is on top.
RCR
Total ratings: 102
Report this Post05-12-2011 10:01 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
BEWARE most GM replacement bearings even oem come from china and you want USA made only
Joe, new question....
Is there a way to tell if the hub is rebuildable (nut instead of crimp) without taking the hub out and popping the back cover? I found a 2004 Buick Century wtout ABS (pn 512221) and the spec sheet looks perfect. I just do not know if the bearing comes apart.
thanx for any help...
Bob
RacerX11
Report this Post05-12-2011 10:55 PM Click Here to See the Profile for RacerX11Send a Private Message to RacerX11Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bob
In my experience, no. I recently bought a made-in-USA, Timken 513018, non-ABS, 5x115mm hub from Rock Auto. Upon pulling the cover, I discovered it is a crimp-style hub, with ball bearings instead of rollers, and the crimp collar has the teeth for ABS. I suspect they are consolidating parts to save money, so the only difference between an ABS and non-ABS hub is the sensor and cover. So you really can't tell until you pull the cover.
Total ratings: 237
Report this Post05-13-2011 06:28 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are there any 5x115 hubs that use roller bearings?
AMC Eagle front hubs use dual tapered rollers and are repackable, but they're 5x4.5.
bubbajoexxx
Total ratings: 112
Report this Post05-13-2011 03:56 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
5x115 and 5x4.5 are the same as far as wheel bolt pattern are concerned
Total ratings: 237
Report this Post05-13-2011 07:15 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, they're not.
joshua riedl
Report this Post05-13-2011 07:55 PM Click Here to See the Profile for joshua riedlSend a Private Message to joshua riedlEdit/Delete MessageReply w/QuoteDirect Link to This Post
I looked it up and it seems the difference is .027''. If I were to order two sets of rims with both patterns would they actually be different?
