  newest project (Page 68)
This topic is 78 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22   23   24   25   26   27   28   29   30   31   32   33   34   35   36   37   38   39   40   41   42   43   44   45   46   47   48   49   50   51   52   53   54   55   56   57   58   59   60   61   62   63   64   65   66   67   68   69   70   71   72   73   74   75   76   77   78
newest project by bubbajoexxx
Started on: 09-12-2003 06:18 PM
Replies: 3111 (375603 views)
Last post by: Trinten on 04-23-2023 11:02 PM
Total ratings: 237
Report this Post05-13-2011 08:55 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
How far do you want to bend your lug studs?
I'll use these, but I'm not going to be so sloppy as to bolt up mis-matching patterns because they're "close".
Ctrl-F "Variation Nut":
http://www.serpentautosport...20and%20Spacers.html
These nuts allow wheels and hubs with slighly mis-matched bolt circles to be assembled. They could be used to:
Mate 120.65mm (4.75" Chevy pattern) to 120mm (BMW pattern)
OR (as relevant to the Fiero community)
Mate 114.3mm (4.5" Everything but GM pattern) to 115mm (GM large FWD pattern)
This satisfies my OCD with regard to avoiding side-loading the lug studs with slightly mismatched patterns.
Obviously use of these requires that appropriate attention be paid to adapting center bore diameters to keep the wheel hub-centric.
bubbajoexxx
Total ratings: 112
Report this Post05-13-2011 08:55 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
been putting GM 115's on ford rangers for years .027 is nothing
Total ratings: 237
Report this Post05-13-2011 08:57 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which only demonstrates that you're a mechanical hack.
bubbajoexxx
Total ratings: 112
Report this Post05-13-2011 09:00 PM Click Here to See the Profile for bubbajoexxxClick Here to visit bubbajoexxx's HomePageSend a Private Message to bubbajoexxxEdit/Delete MessageReply w/QuoteDirect Link to This Post
get stuffed you arogant sob I have been building cars long before you where born
joshua riedl
Report this Post05-13-2011 10:30 PM Click Here to See the Profile for joshua riedlSend a Private Message to joshua riedlEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, Will can be a little rough around the edges. Too much time on the internet maybe. I really wonder if aftermarket wheel manufacturers even care, they probably oversize the holes a little and split the difference. I'm not buying two sets of wheels to find out though.
Fiero2m8
Report this Post05-15-2011 11:46 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I see we're on page 68 now
While I was at the wreckers on Saturday picking up rocker panel covers for my Mercedes, I also picked up this:
I also found this 85 SE V6 with A/C which might come in handy if need more misc. parts when I reassemble mine:
Also, question for Joe...I installed the suction and liquid lines today but noticed 3 wires from the compressor.
One come from the clutch and the other two from the main housing.
How do I wire these up connecting to the 2 wires (yellow and green) from the harness?
Fiero2m8
Report this Post05-16-2011 01:26 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've wondered about the coolant tube crossing the engine bay. It's a bit distracting. What about running it along the side and rear and painting it black?
Okay this mod is finally done...
Last week I tried this setup but there were two issues:
1. I didn't like the fact that the coolant reservoir was no longer the highpoint in the system
2. The stainless line returning from the passenger rad to the waterpump developed a leak in the hose itself about a foot from the rad
That meant draining the DEXCOOL yet again
I decided to keep the other stainless hose as a spare for my upper rad hose (that doesn't leak) and went back the a hard line setup for the return
Cooling system is refilled with no leaks.
All the air bubbles are gone.
The guage is reading correctly with fans coming on above T-stat rating.
Gokart Mozart - your suggestion has been granted
Fiero2m8
Report this Post05-18-2011 09:09 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
For the engine cover I wanted a tidy modern look with side benefit of less visible parts to keep clean:
Sitting on top it's really far from the valve covers while vacuum tubes are in the way of stock location so I have two ideas to lower it to somewhere is the middle.
A - cut 8 holes in it for velocity stacks so it hides some plumbing but carbs still visible
B - only use the centre section between the carbs just above the throttle linkage
If I don't like option A result I can still try option B but not the other way around.
Here was Gokart's photoshop idea:
Here' option A:
Provide your feedback to help me decide...
Mystik
Report this Post05-19-2011 12:36 AM Click Here to See the Profile for MystikSend a Private Message to MystikEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm a fan of the bare look. The extra aesthetic pieces don't really do it for me, just detracts from the engine's natural beauty IMO.
but I'm kind of interested in how it's all interlocked, so I'm strange.
As a side note, I think this would look better than the other option.
Mystik
Report this Post05-19-2011 12:38 AM Click Here to See the Profile for MystikSend a Private Message to MystikEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mystik
Member since Feb 2011
Also, what yard did you find that at? I've been looking all around for Fieros in the area, I can't seem to find any.
Fiero2m8
Report this Post05-19-2011 11:39 AM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for feedback - here's the yard info...
http://www.millersauto.com/
Total ratings: 237
Report this Post05-19-2011 12:44 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ditto
Total ratings: 259
Report this Post05-19-2011 01:39 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am fan of the bare look as well. Every time I see an engine cover I wonder what ugliness they are trying to hide with it.
ezramore
Report this Post05-19-2011 02:42 PM Click Here to See the Profile for ezramoreSend a Private Message to ezramoreEdit/Delete MessageReply w/QuoteDirect Link to This Post
What if you used it to cover the coil pack area instead. Would reduce the dirt blowing up from under the car a little. I agree with others that it takes away from the look of the engine otherwise.
Fiero2m8
Report this Post05-19-2011 02:46 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Exposed is getting votes. I'm going to try another option of 2 large holes so the entire carbs stick through and only the empty valley is covered.
Indy Northstar-Stretch ~ LT1-NOS Roadster
Fiero2m8
Report this Post05-19-2011 02:51 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Member since Feb 2006
Then people will say why cover the nice wires and coils....but I've thought about that too
Fiero38SC
Report this Post05-20-2011 09:59 AM Click Here to See the Profile for Fiero38SCSend a Private Message to Fiero38SCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like the idea of having a cover, it is a more modern look.
How about a custom cover out of stainless or powder coated to match? Cover the center and have the sides bend down near the valve covers much like the Caddy cover. Make 4 elongated holes for each pair of stacks. Also bend down the back to cover the difference in height that will be needed to cover the center linkages and the plug wires.
I think the extra badging for "Northstar 32 Valve" on the cover is redundant when placed next to the valve covers. If you want to keep the Caddy logo, add it to the new cover either in the center or along the centerline near the back of the cover.
Maybe someone can photoshop this idea?
doublec4
Total ratings: 150
Report this Post05-20-2011 09:59 AM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I vote no cover. Looks much better without.
Tinkrr
Report this Post05-20-2011 11:16 AM Click Here to See the Profile for TinkrrSend a Private Message to TinkrrEdit/Delete MessageReply w/QuoteDirect Link to This Post
No Cover
I've always thought that manufacturers who cover up their engines are trying to hide something or they're ashamed of them.
1988holleyformula
Total ratings: 68
Report this Post05-21-2011 01:39 AM Click Here to See the Profile for 1988holleyformulaSend a Private Message to 1988holleyformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Please forgive the following Photobucket edited photo, (edit: awesome, its over 300k, so my horrible art won't show up to any but those who are prepared ) but I really wanted to convey my idea, that was based off Gokart's.
So basically that same cover with the 4 parallel raised lines, placed right on top of the polished area in between the carbs. Paint or powdercoat (or whatever works) the cover black, with the Caddy logo right in the center.
Make sense? It still exposes much of the engine's character, but dresses it up at the same time.
I also want to see your photoshop of the "option of 2 large holes so the entire carbs stick through and only the empty valley is covered."
Fiero38SC's idea sounds good too!
Really amazing build you have here!
[This message has been edited by 1988holleyformula (edited 05-21-2011).]
dratts
Total ratings: 118
Report this Post05-21-2011 12:26 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have two N* Fieros. One with the cover and one without. The one without could use a cover to hide the " busy Look"
of the engine, but I sure wouldn't hide an engine like yours.
[This message has been edited by dratts (edited 05-21-2011).]
Fiero2m8
Report this Post05-23-2011 06:04 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the suggestions.
I marked out the openings for the carbs here:
However I realized that they would still cover up the intake manifolds which I wanted to keep visible.
So I ended up cutting out the center section and removing the emblem so it could be rotated 90 degrees.
I agree that the extra badging is duplication and it was only on one side anyways so not needed above the valve covers.
Here's my idea to cover the valley only and keep everything above exposed (including the throttle linkage)
Does this look like a suitable compromise?
thedrue
Report this Post05-23-2011 06:37 PM Click Here to See the Profile for thedrueSend a Private Message to thedrueEdit/Delete MessageReply w/QuoteDirect Link to This Post
That looks very nice. Subtle and you can still see the workings of the engine.
I like it, thumbs up!
kennn
Report this Post05-23-2011 09:50 PM Click Here to See the Profile for kennnSend a Private Message to kennnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, subtle and tidy.
Ken
'88 Formula V6
'88 GT TPI V8
Gokart Mozart
Total ratings: 159
Report this Post05-24-2011 10:44 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
1988holleyformula
Total ratings: 68
Report this Post05-25-2011 04:13 PM Click Here to See the Profile for 1988holleyformulaSend a Private Message to 1988holleyformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's exactly what I was trying to convey with my poor Paint photo! Looks great!
Fiero2m8
Report this Post05-26-2011 10:56 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok cover is repainted silver and emblem glued and reinstalled.
New spark plugs are gapped / installed just need to refurb throttle linkage:
Working on covering rest of the engine harness...
Fiero2m8
Report this Post06-01-2011 01:10 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Almost done with the wiring cleanup...
Fiero2m8
Report this Post06-04-2011 09:58 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
I picked up some LED lamps to use as reverse lights.
Since the old ones never worked I installed a new backup switch in the transaxle.
I also ran a new +12V (power with ignition on) wire so lights can't be left on.
Here's a picture of them wired up, with key on and shifter in reverse - it works
Then I was able to finally finish installing the wire loom within the engine bay:
Total ratings: 237
Report this Post06-05-2011 08:36 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is anything else hooked up to the Caddy overflow tank?
ezramore
Report this Post06-06-2011 10:26 AM Click Here to See the Profile for ezramoreSend a Private Message to ezramoreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a thought where the rad hose rests on the sharp metal edge of the cut mesh.
http://www.directindustry.c...ors-11859-31825.html
Fiero2m8
Report this Post06-07-2011 05:24 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Will,
Both top and bottom connections are hooked up.
Fiero2m8
Report this Post06-07-2011 05:26 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Yes good suggestion.
I currently have rubber under the hose but also have some rubber door edge molding I please to add where the metal is cut.
This will be done soon prior to the car moving.
nathrak
Report this Post06-07-2011 11:47 PM Click Here to See the Profile for nathrakSend a Private Message to nathrakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, will be heading north of the border (to North York) the first week of july and would love to see this car in person if it's out and about on the road.
Fiero2m8
Report this Post06-08-2011 05:24 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Send me a PM then - will try my best to be ready.
Fiero2m8
Report this Post06-08-2011 07:17 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero2m8
Completed new throttle linkage setup.
Started by rebuilding the broken linkage with new helm joint.
They came very stiff, so I little tap with the hammer and socket loosened them up to swivel freely:
Due to the valley cover, I needed to raise it, so I used new stainless bolts, washers and chrome tubing as spacers to get the clearance I needed.
To avoid linkage binding I reversed the mounting points from above to below to keep the joints horizontal:
Finished it off with rubber caps on top. The throttle stops snap back even when only one side is connected so I have good throttle response and consistent idle control:
Gokart Mozart
Total ratings: 159
Report this Post06-08-2011 07:35 PM Click Here to See the Profile for Gokart MozartClick Here to visit Gokart Mozart's HomePageSend a Private Message to Gokart MozartEdit/Delete MessageReply w/QuoteDirect Link to This Post
spin the crest: put the caddy logo on top... nah
ezramore
Report this Post06-09-2011 02:37 PM Click Here to See the Profile for ezramoreSend a Private Message to ezramoreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you box in the vally cover to go over the link
Total ratings: 237
Report this Post06-10-2011 11:20 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update for fieroguru:
After some more R&D we are going to mod Bearing #513009 instead due to its smaller size 2.79" vs. 88 spindle of 2.74"
Timken or FAG #513009
Cross Ref #7466902 7470539 7470540
Non-Drive (FWD)
REAR w/Disc Brakes
Non-ABS
Fits:
1979-1985 Buick Riviera
1979-1985 Cadillac Eldorado
1980-1985 Cadillac Seville
1979-1981 Oldsmobile Toronado
1982-1985 Oldsmobile Toronado
http://www.alibaba.com/prod...eel_unit_513009.html
What dimension are you referring to? The OD of the housing?
Fiero2m8
Report this Post06-10-2011 10:23 PM Click Here to See the Profile for Fiero2m8Click Here to visit Fiero2m8's HomePageSend a Private Message to Fiero2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes like this picture
To do this
